Hi I do not know how to install the generic thermostat integration. When I go to Settings- Devices& Services ADD INTEGRATION button can’t see it .
Hi , thanks fro reply.
I did this… I generated in config/Climate/ Generic_thermostat.yaml
climate:
- platform: generic_thermostat
heater: switch.termostatnanoswgen5
target_sensor: sensor.lumi_lumi_weather_73a3f207_temperature
min_temp: 12
max_temp: 25
ac_mode: false
target_temp: 17
cold_tolerance: 0.3
hot_tolerance: 0
min_cycle_duration:
seconds: 5
keep_alive:
minutes: 3
initial_hvac_mode: "off"
away_temp: 16
precision: 0.1
And include this file in configuration.yaml
climate: !include Climate/Generic_thermostat.yaml
Now I deleted the first line from my yaml file and it works , so was a coding problem.
I am a beginner and maybe I do not use all terms correctly .
Here’s why:
Your original config include would have resolved to this:
climate: # !include resolves here and below
climate: # <-- double "climate:" is not correct config.
By removing that first line it now correctly resolves to:
