So I’m using a broadlink rm4 pro to control a propane gas stove in my basement. All works absolutely fantastic (and WAF is through the roof since her office is down there). There’s just one small exception - that is that sometimes it doesn’t pick up the radio signal and the state gets out of sync. I think the keep_alive option should handle that scenario right?
If I understand the documentation here (https://www.home-assistant.io/integrations/generic_thermostat/) correctly, then it SHOULD send the switch on or off command repeatedly at a given interval? If that’s the case then it doesn’t appear to be working correctly.
I’ve tested it by turning the fireplace on, then unplugging the RM4, turning off the switch in home assistant then plugging it back in. My expectation is that after the timeout (1 minute in my case), the broadlink device would send an off signal but that doesn’t appear to happen.
If anyone has any suggestion I’d love to hear it. Seems like this all works for other people so I gotta think there’s something I’m doing wrong. Maybe there’s something wrong with my config? I think it’s all right, but who knows. Here’s the relevant bits:
configuration.yaml:
switch:
switches:
fireplace:
value_template: "{{ is_state('input_boolean.fireplace_state', 'on') }}"
turn_on:
# Turn on fireplace depending on selected level
- choose:
- conditions:
- condition: state
entity_id: input_select.fireplace_level
state: low
sequence:
- service: script.fireplace_low
- conditions:
- condition: state
state: medium_low
sequence:
- service: script.fireplace_medium_low
- conditions:
- condition: state
state: medium
sequence:
- conditions:
- condition: state
state: high
sequence:
- service: script.fireplace_high
- conditions:
- condition: state
state: ridiculous
sequence:
- service: script.fireplace_ridiculous
turn_off:
- service: script.fireplace_off
climate:
- platform: generic_thermostat
heater: switch.fireplace
target_sensor: sensor.basement_temperature
cold_tolerance: 0.5
hot_tolerance: 0.5
min_cycle_duration:
minutes: 5
keep_alive:
minutes: 1
precision: 0.1
scripts.yaml:
fireplace_off:
alias: Fireplace Send Command Off
sequence:
- service: input_boolean.turn_off
entity_id: input_boolean.fireplace_state
- service: remote.send_command
command: b64:eMCQAoLOBAAoG...........
entity_id: remote.universal
mode: queued
fireplace_low:
alias: Fireplace Send Command Low
sequence:
- service: input_select.select_option
option: low
- condition: state
entity_id: climate.basement
state: 'heat'
command: b64:d8CGArDNBAApGg4NDwwcGxsbGw4.............
mode: queued
etc, etc.
