I am new here so please correct me if I am asking incorrectly.
I am wanting to use Generic Thermostat however I am experiencing the following:
When I add generic thermostat to a Dashboard I receive the message “No matching entities found:”
Climate is not shown under Developer Tools - States, or Developer Tools - Services
Below is my .yaml file:
climate
- platform: thermostat
entity: climate.observatory # I just tried this to see any difference
heater: switch.observatory_fan
target_sensor: sensor.observatory_temperature
min_temp: 10
max_temp: 30
ac_mode: true
target_temp: 20
cold_tolerance: 0
hot_tolerance: 1
min_cycle_duration:
seconds: 5
keep_alive:
minutes: 3
initial_hvac_mode: "off"
away_temp: 20
precision: 0.1
Arh
December 5, 2022, 7:16am
2
This is my code, platform might be the issue.
climate:
- platform: generic_thermostat
heater: switch.heating
target_sensor: sensor.heating_ds18b20_temperature
min_temp: 15
max_temp: 25
ac_mode: false
target_temp: 20
cold_tolerance: 0.3
hot_tolerance: 0
min_cycle_duration:
seconds: 5
keep_alive:
minutes: 3
away_temp: 5
home_temp: 20
activity_temp: 15
precision: 0.1
colon after climate… i.e climate:
Thanks for the help. Unfortunately the result is still the same. I do note that there is the following error as well, when I try to create the Generic_Thermistat on a dashboard. I get the following error proceeded by a red ! in a red circle. Climate is not shown under Developer Tools - States, or Developer Tools - Services (is this relevant?
"Specify an entity from within the climate domain
type: thermostat entity: ’ ’ "
Thanks heaps in advance.
Arh
December 5, 2022, 10:24am
5
I assume you have read the docs
This is what you need to create, I think??
brussel
(Brent Russell)
June 27, 2023, 11:07am
6
@Arh did you add the lines to your configuration.yaml or a separate yaml file. I could only get it to work if it was in the configuration.yaml.
Arh
June 27, 2023, 3:44pm
7
If I remember correctly it needs to be in configuration.yaml . But i have not used that for 6 months or so I have a different setup useing Esphome now.
