I am looking for help. I have in the past used the thermostat card in the UI but since the update I hit a dead end. My config.YAML is as before and confirms as good. When I come to set up the card on the UI I am asked to specify an entity from the climate domain, go to the drop down box and get “No matching entity” Spent hours on this and just wonder what I am doing wrong?
climate:
- platform: generic_thermostat
heater: switch.heater_switch
target_sensor: sensor.heat_sensor
min_temp: 20
max_temp: 30
hot_tolerance: 0.5
target_temp: 25
min_cycle_duration:
seconds: 5
initial_hvac_mode: “off”
away_temp: 25
precision: 0.1
Any help most appreciated.
