I have configured a generic thermostat with a aeotec multisensor providing the temperature reading, and two fibaro wall plugs turning on or off two electric heaters in my room. I haven’t been able to pinpoint if my problems occur at startup and last until I restart, or if they are transient, but relatively often home assistant simply doesn’t turn the switches on or off. Even if the setpoint is 15 deg Celsius and the reported temperature is 25 degrees, the switches will stay on permanently, and the other way around. Mind you the configuration does work about 50% of the time, so I don’t feel that this is an issue in the way I have configured the thermostat.
As I am new to Home Assistant (migrated recently from OpenHAB), I’m not sure how to troubleshoot this further. I can’t find any relevant info in the home-assistant.log-file. Has anyone experienced this issue, or have a tip on how I can troubleshoot this?
Thanks! No, I don’t see any listings for generic_thermostat or any other automation for that matter. It only shows updates of sensors and input_booleans/selects/slides.
I am also having the same problem in version .80.1
Sometimes it won’t shut off after hitting setpoint, sometimes it is not turning on the Fibaro wall plug. The thermostat itself believes that the wall plug is on (showing green in the graph). I do not have any coverage issues, it is just 4 metres away from the UZB z-wave stick.
