When the thermostat is set to a specificed temperature (lets say 17C) after few seconds it automatically resets to the minimum value mentioned in the YAML configuration.
Following in the generic thermostat configuration:
- platform: generic_thermostat
unique_id: generic_home_thermostat
heater: switch.shellyplus1
target_sensor: sensor.temp_hum_living_room_temperature
min_temp: 16
max_temp: 22.5
target_temp: 17
# ac_mode: false
cold_tolerance: 0.5
hot_tolerance: 0.1
keep_alive:
seconds: 450
min_cycle_duration:
minutes: 10
precision: 0.5
It regularly keeps setting to minimum temperature within seconds even if i manually adjust the temperature dial. I don’t have any automations running. Logs don’t show anything useful too. All i get in logbook is “switch.shellyplus1 turned on triggered by service Climate: Set target temperature” and "switch.shellyplus1 turned off triggered by service Climate: Set target temperature
Any advice?
