Since release 2024.8 integrations set up using YAML should be visibile in the UI. For some integrations e.g. Emulated Hue this is indeed the case, but for my climate entities based on platform generic_thermostat this is not the case.
I’m running Core 2024.10.3, Supervisor 2024.10.3, Operating System 13.1 and Frontend 20241002.3 on a Hardkernel ODROID-N2/N2+.
configuration.yaml excerpt:
climate: !include climate.yaml
climate.yaml content:
- platform: generic_thermostat
unique_id: 16679
heater: switch.cv
target_sensor: sensor.living_room_temperature
min_temp: 15
max_temp: 22
cold_tolerance: 0.2
hot_tolerance: 0
keep_alive:
seconds: 30
target_temp_step: 0.5
away_temp: 16
comfort_temp: 20.5
precision: 0.1
unique_id: 17679
heater: switch.mit
min_temp: 15
max_temp: 22
cold_tolerance: 0
hot_tolerance: 0.6
keep_alive:
seconds: 30
away_temp: 16
comfort_temp: 20.5
precision: 0.1
unique_id: 17669
heater: switch.infrarood_kachel_stopcontact_1
target_sensor: sensor.study_temperature_study_temperature
min_temp: 18
max_temp: 23
cold_tolerance: 0.2
hot_tolerance: 0.1
keep_alive:
seconds: 30
precision: 0.1
Any help is appreciated!
