Generic Thermostat - Select Temp sensor
I have setup a Generic Thermostat, and it works really good.
I want to add a feature in order to select a specific Temperature Sensor in Haas interface for my thermostat without reloading.
The goal is the use the bedroom sensor instead of the livingroom sensor when i use my wood stove.
Does anyone have an idea of how to make such a thing. If not possible I will add a 2nd Generic Thermostat, but I would prefer keep only one.
Thanks :slight_smile:
what about this ?
  • create input_boolean (or input_select) for choosing a sensor
  • create template_sensor getting temp values from physical sensors, based on input_boolean selection
  • configure thermostat to use template_sensor
Just quick principle :wink:
@milanvo
Many thanks, exactly what I want, and it works. :slight_smile:
I’ve not think to make it this way
:+1: great ! :smiley:
Can you give an example of the code you used? I think I am having a similar problem and I don’t understand what is meant by creating a template_sensor
Here is what I use :
  sensors:
    target_temp_sensors:
      friendly_name: "Target Temperature"
      unit_of_measurement: "°C"
      value_template: >-
          {% if is_state('input_select.target_temperature', 'Salon') %}
              {{ states.sensor.temperature_salon.state  | float }}
          {% elif is_state('input_select.target_temperature', 'Cuisine') %}
              {{ states.sensor.temperature_cuisine.state  | float }}
          {% elif is_state('input_select.target_temperature', 'Chambre') %}
              {{ states.sensor.temperature_chambre.state  | float }}
          {% elif is_state('input_select.target_temperature', 'Chambre Enfant') %}
              {{ states.sensor.temperature_chambre_enfant.state  | float }}
          {% elif is_state('input_select.target_temperature', 'Chambre Amis') %}
              {{ states.sensor.temperature_chambre_ami.state  | float }}
          {% elif is_state('input_select.target_temperature', 'Salle de Bain') %}
              {{ states.sensor.temperature_salle_de_bain.state  | float }}
          {% endif %}
