I have a garage which is pretty expensive to heat. At the moment I use the generic thermostat with an electric radiator + a temp sensor. Is there some way to use the generic thermostat with a condition?
I have set up a binary sensor that returns true of solar is generating more than 1kW. I use this for controlling my dehumidifier amongst other things, but that’s a simple on/off via a switch. What I would like is a way to set e target temperature of say 10 degrees celsius, but only heat when solar is generating electricity.
