I got a unusual device to control mi home temperature.
Simplifying it, I got one switch with a momentary button which one turn on/off the presence. Using this, I can switch on/off but I haven’t got the state in home assistant. We can call it switch.presence.
To stop it I got a different one. switch.turn_off. Momentary push.
To turn it on, I got a another one. switch.turn_on. Momentary push.
The presence button keeps the state always, no matter if I switch on or off the general turn-on turn_off. BUT, only can be operate when the general device is on.
Of course, I also got a sensor which one reports the temp.
So…is there any way to create a thermostat with this configuration.
switch.toogle_presence - momentary push button, turn on /off presence without status report. Only works when the general heater is on.
switch.turn_on- momentary push button, turn on general heater.
switch.turn_off - momentary button, turn off general heater.
sensor.home_temp - reports home temp.
This installation works in that way because I’m using a relay to push physical buttons of this device. Is not possible to replace it.
heater string Required entity_id for heater switch, must be a toggle device. Becomes air conditioning switch when ac_mode is set to true.
My only thought is you create a sensor that is set by the two switches through an automation. And when the thermostat sets the sensor you have another automation that shuts off the system. see here
Thanks! with the linked guide, I have created a helper which works as a toogle. This can show the status of the general installation ussing the next configuration.
HELPER: input_boolean.calefaccion
AUTOMATION OFF
alias: CALEFACCION - OFF
description: ''
- platform: state
entity_id: input_boolean.calefaccion
to: 'off'
condition: []
- service: switch.turn_on
data: {}
entity_id: switch.apagar
mode: single
AUTOMATION ON
alias: CALEFACCION - ON
description: ''
- platform: state
to: 'on'
condition: []
data: {}
entity_id: switch.encender_manual
mode: single
Now…i’m trying to use it to create a generic thermostat…any advice?
