Generic Ubuntu Installation - HA Fails to Start
All,
Sorry if my searching on the forums is insufficient. I’ve been running into an issue starting up Home Assistant while following this guide Manual installation on a Raspberry Pi. The installation completed without any problems. However, when I run the hass command in the Python3 venv. It hangs on “starting timer” (See below for logs), the message I get is the same regardless of whether I run it in verbose, debug or “–open-gui”. Have I missed something or is there something I haven’t configured that would cause this?
Thanks in advance!
Edit: Forgot to post my machine’s details, I’m running Ubuntu 18.04 Codename Bionic
Logs
2019-07-22 11:21:52 INFO (SyncWorker_5) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2019-07-22 11:21:52 INFO (SyncWorker_2) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config
2019-07-22 11:21:52 INFO (SyncWorker_8) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2019-07-22 11:21:52 INFO (SyncWorker_3) [homeassistant.loader] Loaded group from homeassistant.components.group
2019-07-22 11:21:52 INFO (SyncWorker_5) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2019-07-22 11:21:52 INFO (SyncWorker_9) [homeassistant.loader] Loaded script from homeassistant.components.script
2019-07-22 11:21:52 INFO (SyncWorker_2) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2019-07-22 11:21:52 INFO (SyncWorker_7) [homeassistant.loader] Loaded http from homeassistant.components.http
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2019-07-22 11:21:52 INFO (SyncWorker_4) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2019-07-22 11:21:52 INFO (SyncWorker_0) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2019-07-22 11:21:52 INFO (SyncWorker_1) [homeassistant.loader] Loaded config from homeassistant.components.config
2019-07-22 11:21:52 INFO (SyncWorker_10) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2019-07-22 11:21:52 INFO (SyncWorker_11) [homeassistant.loader] Loaded api from homeassistant.components.api
2019-07-22 11:21:52 INFO (SyncWorker_8) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2019-07-22 11:21:52 INFO (SyncWorker_19) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2019-07-22 11:21:52 INFO (SyncWorker_3) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2019-07-22 11:21:52 INFO (SyncWorker_12) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2019-07-22 11:21:52 INFO (SyncWorker_5) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2019-07-22 11:21:52 INFO (SyncWorker_9) [homeassistant.loader] Loaded history from homeassistant.components.history
2019-07-22 11:21:52 INFO (SyncWorker_2) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2019-07-22 11:21:52 INFO (SyncWorker_7) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2019-07-22 11:21:52 INFO (SyncWorker_13) [homeassistant.loader] Loaded map from homeassistant.components.map
2019-07-22 11:21:52 INFO (SyncWorker_4) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
2019-07-22 11:21:52 INFO (SyncWorker_0) [homeassistant.loader] Loaded person from homeassistant.components.person
2019-07-22 11:21:52 INFO (SyncWorker_14) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2019-07-22 11:21:52 INFO (SyncWorker_15) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2019-07-22 11:21:52 INFO (SyncWorker_1) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
2019-07-22 11:21:52 INFO (SyncWorker_16) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2019-07-22 11:21:52 INFO (SyncWorker_10) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.bootstrap] Setting up {‘system_log’}
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setting up http
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.2 seconds.
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setting up group
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setting up updater
2019-07-22 11:21:52 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up person
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up sun
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up webhook
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up system_health
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up api
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up history
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2019-07-22 11:21:53 INFO (SyncWorker_12) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up config
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up script
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.1 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up tts
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.1 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up automation
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up cloud
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.2 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.2 seconds.
2019-07-22 11:21:53 INFO (SyncWorker_0) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.2 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up notify
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up frontend
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up logbook
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setting up map
2019-07-22 11:21:53 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2019-07-22 11:21:54 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.8 seconds.
2019-07-22 11:21:54 INFO (MainThread) [homeassistant.setup] Setting up default_config
2019-07-22 11:21:54 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.0 seconds.
2019-07-22 11:21:55 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 2.36s
2019-07-22 11:21:55 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2019-07-22 11:21:55 INFO (MainThread) [homeassistant.core] Timer:starting
That’s where it will generally stop until you actually open the frontend in a browser.
Hmm… When accessing it (https://myipaddress:8123/ from the browser I get a timeout but I’ll check the firewall and see if I messed up there.
Thank you!
Yep, that was it. I had typo’d when I added the firewall exception. :man_facepalming:
Thank you again!
