Geofency: Device doesn't show up in known_devices.yaml
Hi there,
I just updated to 0.86.3 and having problems with my geofency integration. I had it up and running before changing from legacy api. Since I didn’t get status updates to the existing entity after update, I removed it from known_devices.yaml and started over again. So I setup the geofency webhook integration, change the entries in the iOS app and successfully sent a status update (acc. to https://www.home-assistant.io/components/device_tracker.geofency/).
Unfortunately I don’t see a new device in known_devices.yaml. Geofency component is running. HA log says “Received message for unregistered webhook”.
Did I miss something?! Hope, someone can help me out with this!
Thanks in advance!
same here, same issue, already listed devices don’t get updated and I get Received message for unregistered webhook, running 0.86.3
additionally you cannot remove Geofency from the integrations screen, clicking the trash icon does not do anything… so I can’t setup a new Geofency integration :frowning:
Problem is solved with v0.87
