I am using Geofency to turn on lights when I arrive at home (status “home” starts automation). Lately it has not been working, something changed after one of the latest upgrades of the HA software.
It changed recently to use web hooks - updated documentation is here:
The documentation changed is here:
To configure Geofency, you must set it up via the integrations panel in the configuration screen. You must then configure the iOS app (via the Webhook feature) to send a POST request to your Home Assistant server at the webhook URL provided by the integration during setup.
Hello
But I’ve got family cloud with 5 iPhone’s and Geofency App on each, and before it was one link like this example https://XXXXXn.duckdns.org:8123/api/geofency?api_password=XXXXXX for each device. But now each device should have own link. How to do it?
Use the same URL across all the phones - each phone includes a UUID as part of its http POST payload (a long hexadecimal number)
Trigger a post in the geofency webhook setup (e.g. “TEST CONNECTION ENTRY”) and note the hexadecimal number displayed.
Use this hex number at homeassistant UI to identify a particular phone; the entity will be device_tracker.<hex_uuid> (e.g. to add it to a devices card on lovelace, edit the UI, edit the card and select the new phone device_tracker from the entity dropdown).
