I am using geofency on hassbian V 0.83.3 and followed the instructions… what I get is a timed out error in the iOS app and this error in the log
Dec 14 15:38:37 hassbian hass[29730]: 2018-12-14 15:38:37 DEBUG (Thread-11) [homeassistant.util.json] JSON file not found: /srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/geofency/.translations/en.json
Dec 14 15:45:01 hassbian hass[29730]: 2018-12-14 15:45:01 INFO (MainThread) [homeassistant.components.http.auth] You need to use a bearer token to access /api/geofency from xxx.xxx.xxx.228
for the api_password in the url I used the longterm token
and also tried the iOS geofency Authentication
My question is which one is to be used?
Also the folder .translations is missing (used the ll -a cmd)
Thanks in advance
