Hi, I’m a newcomer to HA coming from another software tool. Been using Geofency with that for many years without issue. I have Geofency configured and assigned to a person (me) as a device tracker.
Testing the Gefoency webhook for enter/exit correctly updates my presence in HA.
My issue is that when HA is restarted, my state becomes “unkown” and I have to resend the webhook commands from Geofency again to get it updated.
Am I missing something here? I would have thought that HA would “remember” the state prior to the restart.
Any help would be appreciated as I continue to evaluate HA as a viable solution moving forward.
Had same issue for long time. But when geofency sends a new location it’s back again.
I moved to a different way to let HA know we went home of leave… At iPhone I use homekit and his leave arrive automation to turn on a input_switch for every person in household. Works great and even better
Those 2 are in my homekit on my iPhone. So I can turn them on and off manual. I created automations in homekit to do this automatic. 4 in total. 2 for me and 2 for my partner. When I leave turn of this input_boolean and turn on when I arrive.
Then I created a binary_sensor. This is my Group Family. It will turn on when 1 of 2 input_booleans is on.
All my automation in HA is triggered on this sensor.
@poudenes
I took a similar approach but I’m still using Geofency
I have it send the webhook and I’m checking the json.entry data (1=home, 0=away) and store that as an input Boolean. I then have an automation that checks the value and updates a device tracker entry which is linked to my person entity.
The small issue was that on HA restart it would always set the device tracker to away so I created an automation to run on HA start up that checks the value of the input Boolean and updates the device tracker accordingly
