Geolocation of tags send via api from findmysync to HA
Hi, I’m desperately trying to integrate my geolocations from findmysync into the HA. Unfortunately the API only delivers to http sites. I’ve already found information on different locations about the problem. But I can´t get the info I need. I don’t know exactly where to include the code I found in my exact case. What is probably necessary is an entry in Ngnix.config that should look like this:
   location /api {
        proxy_pass http://local.server.ip:8123/api;
        proxy_set_header Content-Type application/json;
        proxy_set_header Authorization "Bearer long-token";
or it should work like this:
 location /api {
        if ($http_authorization != "Bearer <long-tock>") {
        return 401;
        proxy_set_header Authorization $http_authorization;
        proxy_pass_header Authorization;
For me the standard is:
active: false
default: nginx_proxy_default*.conf
servers: nginx_proxy/proxy/*.conf
I have no idea how and where I can get these api instructions into the config - I hope someone can help me. Thanks !
