Geolocation services for Nl? where can we find these providers
HI
I would be interested in having warnings for earthquakes and fires in our surroundings, lets say the wider north western european region.
Not aware of the many publicly available services probable, I like to ask the community where could we find servers to entire in the sensors configuration.
did find the KNMI, our national weather institute pages in this:
http://rdsa.knmi.nl/dataportal and http://rdsa.knmi.nl/fdsnws/event/1/query?includearrivals=true&formatted=true&eventid=knmi2019miza
but that probably isn’t very useful to be used like this: https://www.home-assistant.io/components/nsw_rural_fire_service_feed/
if anyone knows where to find this, please post?
thanks
That KNMI FDSN data source may be a candidate for a geolocation integration. Basically what you are looking for is a feed in a standardised format that you can query in regular intervals and extract at least latitude/longitude and some basic information like magnitude of the earthquake, descriptive location, date and time of first occurrence and last update. And it should be a current feed, for example with the ability to limit by time, and not containing historical data (I have found plenty of these).
According to the fdsnws-event documentation, the query even supports a radius search which further simplifies handling the results from the feed, because the results contains exactly the events to display.
For the existing geolocation integration I have used GeoRSS or GeoJSON feeds. QuakeML looks reasonably straightforward to build an integration for. The above query also supports text output - this may also be sufficient for a simple integration into HA.
I’ve recently built the IGN Sismologia integration for earthquakes on the Iberian peninsula. You could have a look at the structure of the HA integration and the underlying library that interfaces with the GeoRSS feed for some inspiration.
thanks, ill have a look at what you write here, seems very daunting to me still…
would you know of a public site listing these feeds you mention? Or how to best find them?
Sorry, I’m not aware of any particular sites listing available geolocation feeds. I just found them by coincidence or searched for known formats like GeoRSS or GeoJSON.
