Geolocation unreliable?
I have the iOS app running side-by-side with OwnTracks, or not actually running but installed and have two zones setup, home and work.
OwnTracks notifies me on zone changes as far as I can tell everytime, while the HA-app have a hit ratio of maybe 33%.
I have removed OwnTracks from my HS setup so it’s running fully standalone but with the same zones.
Have anyone else noticed that or even have a suggestion if it has something todo with my setup?
I’m thinking that the enter/exit notifications may be a bit flaky. Can you add an automation to your system to send a notification from Home Assistant to the phone whenever the device_tracker.see event is fired? I’ll do the same and see what happens.
Will do boss! :grin:
How would that event trigger look?
Like this?
- alias: 'Test'
    - platform: zone
      entity_id: device_tracker.see
- alias: 'Test'
    - platform: event
      event: device_tracker.see
How can I test that it works correctly?
I restarted HA which sets me as “away”, the manually sent my position through the app so I got marked as “Home”, but that’t didn’t trigger the new automation?
Hmmm, weird. I’m unsure right now, will check when I get home.
Did you find anything @robbiet480?
Any updates? Most of the times I have to open the app for it to send my location and iPhone stats… it would be great if you could find a way to fix this :slight_smile:
