Get a remote image and display on Lovelace
Keen for some advice to create a solution for this:
I have build a remote ESP32/SIM7600 IOT sensor at a remote property. It has a PIR, shock, temp and camera.
IOT device sends images in this format
Build a pane inside of Lovelace. What I need to now figure out is how to get the image off a hosted FTP server and then add to /media/camera/CamImage.jpg.
Started with a Node Red flow but most FTP get’s dont support using a variable i.e., msg.payload unless someone can point me in the right direction. I was filtering by the last image date and then that image was the msg.payload.
So perhaps there is another way to approach this without Node Red? I do want a copy of the image off the FTP and stored local rather than say scraping the image.
Second question is if I store locally to here over writing the /media/camera/CamImage.jpg image how do I show the image in Lovelace pane? At the moment it has the full Home Assistant URL i.e., the URL of the image but I should be able to use a internal path.
Hopefully this makes sense looking for ideas on how to achieve this please?
Ok have the flow now working
[{"id":"467354e6dd094a5f","type":"tab","label":"FTP","disabled":false,"info":"","env":[]},{"id":"693ccb5aebc659fc","type":"inject","z":"467354e6dd094a5f","name":"Get Image every 15 min","props":[{"p":"payload"}],"repeat":"900","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"domain.com/Camera","payloadType":"str","x":170,"y":60,"wires":[["31ff6b36e0b622f5"]]},{"id":"db3c92f6d1276edb","type":"debug","z":"467354e6dd094a5f","name":"Debug Output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":880,"y":340,"wires":[]},{"id":"7a6112c6c872a215","type":"function","z":"467354e6dd094a5f","name":"Filter by modification time","func":"msg.payload = msg.payload.filter(f => f.type === '-' && f.name.endsWith('.jpg'));\nmsg.payload.sort((a, b) => b.mtime - a.mtime);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":490,"y":320,"wires":[["f1bb984e6636c890"]]},{"id":"f1bb984e6636c890","type":"function","z":"467354e6dd094a5f","name":"Get lastest JPG","func":"msg.payload = msg.payload[0];\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":460,"y":420,"wires":[["db3c92f6d1276edb","48739aa8b805ab67"]]},{"id":"31ff6b36e0b622f5","type":"change","z":"467354e6dd094a5f","name":"Move Payload to Filename","rules":[{"t":"move","p":"payload","pt":"msg","to":"filename","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":160,"wires":[["edb48ac579207041"]]},{"id":"48739aa8b805ab67","type":"function","z":"467354e6dd094a5f","name":"Fn add remote file path + image","func":"msg.filename = \"/domain.com/Camera/\" + msg.payload.name;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":390,"y":520,"wires":[["db3c92f6d1276edb","d5c53eae596e0b98"]]},{"id":"edb48ac579207041","type":"ftp in","z":"467354e6dd094a5f","ftp":"88b86ecb9b39502e","operation":"list","filename":"","localFilename":"","name":"List","x":430,"y":240,"wires":[["7a6112c6c872a215","db3c92f6d1276edb"]]},{"id":"d5c53eae596e0b98","type":"ftp in","z":"467354e6dd094a5f","ftp":"88b86ecb9b39502e","operation":"get","filename":"","localFilename":"/media/camera/CamImage.jpg","name":"Get latest image","x":460,"y":620,"wires":[["db3c92f6d1276edb"]]},{"id":"88b86ecb9b39502e","type":"ftp","host":"00.00.00.00","port":"21","secureOptions":"","user":"FTPuser","connTimeout":"30000","pasvTimeout":"10000","keepalive":"10000"}]
So the last piece to the puzzle is the NR flow saves to
So if I want to show a image on the dashboard what is the path to use in a Picture Card Configuration?
image string Required
The URL of an image. When you want to store images in your Home Assistant installation use the hosting files documentation. After storing your files, use the /local path, for example, /local/filename.jpg.
What access does Node Red have?
Works:
Stops Node Red
/local/camera/CamImage.jpg
23 Feb 13:24:43 - [info] [server:Home Assistant] Connected to http://supervisor/core
23 Feb 13:25:03 - [red] Uncaught Exception:
23 Feb 13:25:03 - [error] Error: ENOENT: no such file or directory, open ‘/local/camera/CamImage.jpg’
[13:25:03] INFO: Service Node-RED exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[13:25:03] INFO: Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
