Get all-day events for specific days
As reported here, all-day events will always have an end 1 day after start date.
But, when I want to get_events from a calendar with all-day events for tomorrow only (today is 2024-01-23) with
- service: calendar.get_events
    entity_id: calendar.homeassistant_alldayevents
    start_date_time: '2024-01-24'
    duration:
      days: 1
    response_variable: homeoffice_agenda
I also receive all-day events for today:
homeoffice_agenda:
  calendar.homeassistant_alldayevents:
    events:
      - start: '2024-01-23'
        end: '2024-01-24'
        summary: 'Today event'
(I already tested with other values for duration and end_date_time - also with second granularity.)
How can I restrict the list to only show (all-day) events for tomorrow? I want to check on the events - and don’t want to trigger on them.
(This is my first post here - so let me say “Hi!” first! I searched the forum before I posted here, but found no solution that worked.)
P.S. I saw this thread adding a filter like
 - variables:
      all_events: >-
        {{ homeoffice_agenda['calendar.homeassistant_alldayevents'].events  |
        rejectattr('start', 'eq', today_at().date() | string ) | list }}
But I would imagine this also filters out multi-day events.
FWIW, I couldn’t replicate the problem.
I created three all-day events, each in a separate day (today, tomorrow, and the day after). Then I used Developer Tools > Services to test the service call you posted (using my calendar). The result contained just tomorrow’s all-day event.
The calendar I used for the test uses the Google Calendar integration.
That’s interesting. I use the caldav integration - didn’t think this could be the source of the problem.
Possibly related to this reported issue:
Thanks for pointing that out! You may be right, that this problem is related, although it concerns triggers. I had no problems with states based on all-day events yet, but maybe it’s really an issue with the integration and not with my configuration. Thank you (especially for testing my config with a different integration)!
Sorry for reviving this thread, I just wanted to share what I found out for whoever next might need these insights:
On the linked github issue, allenporter mentioned time zones, which made me try the following:
action: calendar.get_events
  entity_id: calendar.appointments
  duration:
    days: 1
  start_date_time: "2024-11-08T00:00Z"
The Z after the time indicates Zulu Time, aka UTC. You could use UTC or +00:00. Or use midnight UTC in your server time zone – but beware daylight saving time! If you want to save 3 bytes, T00Z would be enough for the time part, but I think it’s easier on the eyes to have T00:00Z.
