Get an alert when ESPHome flash has finished!
My ESPHome flashes take a while and so I get distracted and side-tracked while waiting, then forget to go back to testing/working on them. It would be nice to get an alert of sorts.
The folk over on the ESPHome Discord (well user @antonio-fiol ) suggested including a timestamped ESPHome version sensor in all my ESPHome configs, then watching for any changes.
And I adapted an automation / trigger from over here.
In your all of your ESPHome configs:
# I use substitutions but you don't have to.
substitutions:
friendly_name: This is my device friendly name I like
text_sensor:
# Reports the ESPHome Version with compile date
- platform: version
name: ${friendly_name} ESPHome Version
As a HA automation:
#ESPHome Flash has finished
#Based on this: https://community.home-assistant.io/t/template-to-add-values-of-all-sensors-with-certain-name-ending/64488/21?u=mahko_mahko
#And thanks to Antonio-Fiol on the ESPHome Discord for the suggestion to use the ESPHome version sensor.
- id: '5656254'
alias: An ESPHome Flash has Finished
platform: event
event_type: state_changed
condition:
#Check for substring "_esphome_version" in entity_id
condition: template
value_template: "{{ '_esphome_version' in trigger.event.data.entity_id }}"
#Do something useful.
- service: rest_command.assistant_broadcast
#Include the Friendly name of the ESPHOme device in message. Remove " ESPHome Version" from message.
command: Finished Flashing {{ state_attr(trigger.event.data.entity_id, 'friendly_name') |replace(" ESPHome Version","")}}
It works, but interested to hear if there are more elegant solutions.
Would be cool to know how long the flash took.
