I currently have a RPI 4 with Raspbee II and, of course, HA
I have a garage door controlled by a motor. In the hardware, if we make a connection between two pins (11 and 13), see picture, the motor opens/stops/closes sequentially. Currently, i have a simple button that makes this contact, and allows me to open and close the garage door.
I would have liked to automate this with HA. For this, i think the best is to use a relay, and have if set a contact then stop the contact (simulating a button press).
Do you know what type of device I could use to do that? The ideal would be a Zigbee device with a relay i can switch on-off, but maybe there is another way.
thank you
Ben
