Hi Guys,
i have a meter that only exports 1.8.0 (import) counter (total increasing) to my home assistant instance. The counter will be read every 2 seconds and the value will be sent via MQTT Sensor Message.
I like to get a delta statistic with extrapolate to get Watts per Hour. So if the Meter raises from 0,000 to 0,002 kWh in 2 seconds, that will extrapolate to 0,002 * 30 * 60 = 3600W power. So in first i need a statistic-writer that writes every delta between 2 values. Currently i do the following wich is not functional:
- platform: statistics
name: "Power Wattage 2 sec. average"
unique_id: statistics_power_wattage_2sec_avg
entity_id: sensor.smart_meter_grid_import_watt_hours
state_characteristic: change
sampling_size: 2
precision: 0
sensor.smart_meter_grid_import_watt_hours total increasing - Wh meter counter total
What i am doing wrong? What state_characteristic and sampling-size should i use to get delta values for each update? - Again: the counter updates every 2 seconds.
