Get data from APC Smart + Network Management Card via SMTP
Just wanted to hop and say thanks for this, was debating on doing the APC NIS method but this was much easier!
I’m new to Home Assistant and have an APC SmartUPS 1500 with an NMC2 card installed. I’m on the latest version of HA and all devices have the latest firmware from APC.
From what I understand, the code above acts like a driver to create a new sensor in HA for the APC NMC cards. What I don’t understand is where to put this code. How do I create this new sensor?
Any help would be greatly appreciated.
Inside configuration.yaml
I changed the device name and ip address and pasted the code to the end of configuration.yaml. I then tested it in HA Developer tools. Here is the message:
Error loading /config/configuration.yaml: while parsing a block mapping
in “/config/configuration.yaml”, line 3, column 1
expected , but found ‘’
in “/config/configuration.yaml”, line 18, column 3
I’m trying to add my much older APC SmartUPS 1000XL with a APC9606 network card using SNMP. My baseoid is only 9 to 12 characters .1.3.6.1.2.1.1.1.0 and varies. Nothing like what I’m seeing in this thread.
Also adding the different examples (editing for a single UPS) and inputting the needed changes causes issues.
Solved
Had to place it in with other declared sensor: section in the config.yaml and just change the IP address working like a charm.
If using NUT integration, localhost should be replaced with “a0d7b954-nut”
Hy,
any idea to get the power in Watt?
Steffen
  - platform: snmp
    host: SNMP_IP
    baseoid: 1.3.6.1.4.1.318.1.1.1.4.2.8.0
    accept_errors: true
    unit_of_measurement: 'W'
Supposedly needs to be 6.5 or above - bug in earlier (6.4) version - thankfully I’m already on 6.5
And for Output Voltage, for trimming:
  - platform: snmp
    host: SNMP_IP
    baseoid: .1.3.6.1.4.1.318.1.1.1.4.2.1.0
    accept_errors: true
    unit_of_measurement: 'V'
EDIT: APC UPS Monitoring - Useful OIDs
@man55 thanks a bunch for the OIDs and stuff.
I migrated from NUT, where I had one decimal place for I/O Voltage. Now it’s an int. Any idea where the more detailed reading is coming from? Didn’t found anything ith the PowerMIB.
€: it’s upsHighPrecOutputVoltage.
if you add the device_class: duration to apc2200_smart_runtime you don’t have to typecast into a custom timestamp
  • platform: snmp
    scan_interval: 10
    unique_id: apc_1
    host: 192.168.1.87
    baseoid: 1.3.6.1.4.1.318.1.1.1.4.2.4.0
    device_class: current
    unit_of_measurement: “Amps”
It shows me the number 3, but the APC statistics show 2.8. Is it possible to make the sensor display more accurate values? Or can I only get rounded values using snmp?
Check the MIB with Free MIB Browser / MIB Browser / SNMP Browser. with the APC MIB from here: https://www.se.com/ca/en/download/document/APC_POWERNETMIB_EN/
It’s .1.3.6.1.4.1.318.1.1.1.4.3.4.0 aka upsHighPrecOutputCurrent
