This configuration works nice with APC Smart + AP9617 Smart Slot Network Management Card connected to LAN.
Sensor setup:
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.2.2.1.0
accept_errors: true
unit_of_measurement: '%'
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.2.2.3.0
accept_errors: true
value_template: >-
{% set time = (value | int) / 100 | int %}
{% set minutes = ((time % 3600) / 60) | int %}
{% set hours = ((time % 86400) / 3600) | int %}
{% set days = (time / 86400) | int %}
{%- if time < 60 -%}
Less than a minute
{%- else -%}
{%- if days > 0 -%}
{{ days }}d
{%- endif -%}
{%- if hours > 0 -%}
{%- if days > 0 -%}
{%- endif -%}
{{ hours }}h
{%- endif -%}
{%- if minutes > 0 -%}
{%- if days > 0 or hours > 0 -%}
{%- endif -%}
{{ minutes }}m
{%- endif -%}
{%- endif -%}
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.4.2.3.0
accept_errors: true
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.2.2.2.0
accept_errors: true
unit_of_measurement: '°C'
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.2.2.4.0
accept_errors: true
value_template: >-
{%if value == '1' %}
Good
{% elif value == '2' %}
Failed
{% endif %}
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.1.1.1.0
accept_errors: true
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.3.2.1.0
accept_errors: true
unit_of_measurement: 'V'
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.3.2.5.0
accept_errors: true
value_template: >-
No events
High line voltage
{% elif value == '3' %}
Brownout
{% elif value == '4' %}
Loss of mains power
{% elif value == '5' %}
Small temporary power drop
{% elif value == '6' %}
Large temporary power drop
{% elif value == '7' %}
Small spike
{% elif value == '8' %}
Large spike
{% elif value == '9' %}
UPS self test
{% elif value == '10' %}
Excessive input voltage fluctuation
{% endif %}
- platform: snmp
host: SNMP_IP
accept_errors: true
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.4.2.4.0
accept_errors: true
unit_of_measurement: 'A'
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.7.2.3.0
accept_errors: true
value_template: >-
OK
Failed
Invalid Test
Test In Progress
{% endif %}
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.7.2.4.0
accept_errors: true
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.8.1.0
accept_errors: true
value_template: >-
on
off
{% endif %}
- platform: snmp
host: SNMP_IP
baseoid: 1.3.6.1.4.1.318.1.1.1.4.1.1.0
accept_errors: true
value_template: >-
Unknown
On Line
On Battery
On Smart Boost
Timed Sleeping
Software Bypass
Off
Rebooting
Switched Bypass
Hardware Failure Bypass
{% elif value == '11' %}
Sleeping Until Power Returns
{% elif value == '12' %}
On Smart Trim
{% endif %}
homeassistant:
customize:
sensor.ups_smart_status:
device_class: connectivity
friendly_name: Smart-UPS status
sensor.ups_smart_capacity:
device_class: battery
xbmcnut
(xbmcnut)
July 4, 2020, 11:33am
2
Thanks for this. To be clear, if you use this method, do you not need to go the route of the Network UPS Tools add-on and Integration ?
Yes, with this method you need nothing else.
xbmcnut
(xbmcnut)
July 5, 2020, 10:35am
4
Thanks! Iâve chucked it in as a package and itâs working a treat.
pstoian
(Petrica Stoian)
August 19, 2020, 6:52pm
5
Thank you @xbmcnut for recommending this configs - it is working fine.
great job @aqualx for sharing this configs. Great job !!!
Anyway - I have one question - how I will change the temperature from Celsius to F ? I tried and shows the same Celsius value. I checked into my UPS web portal and I have the ups set up to F .
aqualx
August 20, 2020, 8:33am
6
If problem is in display unit, than change everywhere:
to
unit_of_measurement: '°F'
pstoian
(Petrica Stoian)
August 20, 2020, 2:33pm
7
@aqualx - made the change but still showing the Celsius value even after the HASS restart. (see below snip)
Also it shows me the UPS is on battery - is that normal ? shouldnât say on power or something ?!
pstoian
(Petrica Stoian)
August 26, 2020, 10:20pm
9
Thank you @aqualx . I was able to fix the temperature measurement ( I had to updated all the local users in the card to US Customary) and also I removed the % from sensor definition.
I am planning to add the secondary UPS card - by adding UPS02 to the name string - hope will work.
Great work again !!!
pstoian
(Petrica Stoian)
September 18, 2020, 5:03pm
10
adding multiple UPSs is working as well - I was able to add the second UPS by changing the host IP and name for identification.
Great job !!!
i added to lovelace but i got âunknownâ
I donât understand how to configure please explain to me where the text should be put?
config.yaml or other?
in the board / ups setup I have to do something
thanks
aqualx
December 18, 2020, 9:13pm
12
If all your configuration is in configuration.yaml
, than put it there.
You will need replace SNMP_IP
with real address of your APC.
I did as you told me but nothing
Solved
set SNMPv1
Community Name : public
Hostname : 0.0.0.0
Access Type: Read
perfect work
safepay
(Richard Mann)
March 22, 2021, 5:42am
16
This is an excellent post, however, the Home Assistant NUT tools provide a very easy way to configure the UPS via SNMP and provide automatic shutdown:
Install the Hassio NUT add-in via the Supervisor: https://github.com/hassio-addons/addon-nut
Configure it - here is my config. Just set the host to the IP address of your UPS network address and set your own username and password for the HA integration.
Make sure the UPS access control for SNMP v1 is in a profile called public
and is accessible (E.g. 0.0.0.0)
users:
- username: username
password: password
instcmds:
- all
actions: []
devices:
- name: ups
driver: snmp-ups
port: 192.168.1.???
config: []
mode: netserver
shutdown_host: 'true'
Then install the NUT integration as per the instructions: https://www.home-assistant.io/integrations/nut/
I just tried setting this up with my UPS, but Nut complains it doesnât know what to do with the MIB that was found:
No matching MIB found for sysOID â.1.3.6.1.4.1.318.1.3.27â!
Please report it to NUT developers, with an âupscâ output for your device.
Going back to the classic MIB detection method.
But when I ssl into HA, I try the upsc command, and it says upsc isnât found.
I am using an APC SRT 8000 (which BTW I picked up on a craigslist sale for $300!)
EDIT: Sorry, I figured out I needed to stick a port number in the network config below so the integration would actually work. Things seem ok now!
Where did you stick that port number? And what port was NUT looking for? I have the same issue here.
@fdlou147 I had to add 3493 in the Network section of the config page, down at the bottom. Once I did that, the UPS info updated just fine.
man55
(Man55)
February 12, 2023, 10:24pm
21
Just use one line for the runtime. You donât need that bunch of code with lots of ifs ifs ifs )))
value_template: "{{((value | int) / 100)|timestamp_custom('%-H hours %-M min', false)}}"
Itâs also convenient to use device_class: battery
for batt capacity and the system will automatically detect the icon and change it depending on the state.
Also use a unique_id for each sensor, this will allow you to change their names and icons directly in UI
unique_id: apc2200_smart_battery_voltage
man55
(Man55)
February 12, 2023, 10:32pm
22
My code:
# APC 2200 snmp
- platform: snmp
unique_id: apc2200_smart_type
host: 192.168.1.50
accept_errors: true
- platform: snmp
scan_interval: 10
unique_id: apc2200_smart_status
host: 192.168.1.50
accept_errors: true
value_template: >-
Unknown
Online
On Battery
On Smart Boost
Timed Sleeping
Software Bypass
Off
Rebooting
Switched Bypass
On Smart Trim
{% endif %}
- platform: snmp
scan_interval: 10
host: 192.168.1.50
baseoid: 1.3.6.1.4.1.318.1.1.1.2.3.4.0
device_class: voltage
unit_of_measurement: "V"
accept_errors: true
value_template: "{{((value | int) / 10)}}"
- platform: snmp
scan_interval: 10
unique_id: apc2200_smart_battery_capacity
host: 192.168.1.50
unit_of_measurement: "%"
accept_errors: true
- platform: snmp
scan_interval: 10
unique_id: apc2200_smart_input_voltage
host: 192.168.1.50
accept_errors: true
- platform: snmp
scan_interval: 10
unique_id: apc2200_smart_output_frequency
host: 192.168.1.50
baseoid: 1.3.6.1.4.1.318.1.1.1.3.3.4.0
accept_errors: true
- platform: snmp
scan_interval: 10
unique_id: apc2200_smart_load
host: 192.168.1.50
baseoid: 1.3.6.1.4.1.318.1.1.1.4.3.3.0
accept_errors: true
- platform: snmp
scan_interval: 10
unique_id: apc2200_smart_ups_temperature
host: 192.168.1.50
device_class: temperature
unit_of_measurement: "°C"
accept_errors: true
- platform: snmp
scan_interval: 10
unique_id: apc2200_smart_runtime
host: 192.168.1.50
accept_errors: true
value_template: "{{((value | int) / 100)|timestamp_custom('%-H гОд %-M Ń
в', false)}}"
