Get data from sensor after every 2 seconds
Hello I am new to Home Assistant .Currently i’m using rest sensors to hit external API and get sensor data from it. Just for testing i’m using ngrok url. I get hit to API after every 30 seconds even though i have set timeout to 10 seconds or even 45 seconds. I don’t know actually where is the issue. Here is my code written inside configuration.yaml .
  - platform: rest
    resource: "http://2934854d0430.ngrok.io/input"
    payload: '{"profile":"status_text"}'
    timeout: 10
    force_update: true
    headers:
      User-Agent: Home Assistant
      Content-Type: application/json
    value_template: '{{ value_json.message }}'
That is not what timeout is for, scan_interval on the other hand is what you are looking for.
It’s not mentioned as a setting but it’s part of sensors.
Use CTRL+F and you will find an example.
Thanks alot. :slight_smile:
