I have an inverter from SolarEdge which I have already integrated with HA successfully via the SolarEdge Modbus Integration. Now I also got an EV Charger (Wallbox) from SolarEdge and I was hoping that either via the SolarEdge Modbus integration or via the SolarEdge API integration it would be possible to get the data from the SolarEdge EV Charger as well. But this does not seem to be the case.
Does anyone know a trick / solution? Or would one have to implement a separate integration for the SolarEdge EV Charger?
whoever stumbles across this topic, I have realized that my SolarEdge EV Charger seems to be a Keba Charger „under the hood“. So by using the Keba integration, I was able to integrate it with Home Assistant
I did not have to adjust any hardware.After having installed the charger and connecting it to the home network, the charger provides an admin web interface. Opening that admin interface, it told me already via the browser title that it’s a “KeContact P30” under the hood which made me try out the KEBA integration in Home Assistant and that worked instantly
Hi, Can I ask whether your SolarEdge EV charger is the Keba P30 ??X series??. If you look carefully at the SolarEdge EV configuration manual, you can see that may it is the X series. Can I ask how is it connected to your the inverter? is it wireless to the router? or do you have an ethernet cable
I’m trying to setup the Keba integration with my SolarEdge EV Charger (a SolarEdge labeled P30).
During start of Home Assistant I can an error “Could not find a charging station at %IP%”. I can confirm that I can access the web interface on that IP.
Can you confirm that the integration still works? What firmware version is installed on your charger @the-smart-home-maker ?
I have a SolarEdge EV charger. In my Unifi router it presented itself als an SMA SunnyBoy AV 5.0. Although my installer claimed I should stick to SolarEdge equipment, to assure everything communicated properly, I suspect this realy is an SMA charger in a SolarEdge case. My SolarEdge account does not give access to the charger when I try to login on the local IP address using my SolarEdge credentials .
hi all - after some advice here I have the Solaredge 7kw charger installed. but the rs245 cable was not connected to my inverter So i can’t do the follow mode natively
I do have the solaredge modbus setup for my system working in ha tho. I wsas just going to enable the dipswitch (1.2?) to enable udp and use keba integration to control this
Does anyone else do this here? or would you recommend i just get the cable installed?
Did you ever get yours to work? Seems like you need to enable dip switch 1.3 on the unit. But I’m waiting for solar edge to confirm
I would really like to control it through home assistant especially whether or not I allow solar excess charging only or not. That’s my main use case
