Hello! I have a blueprint that accepts an input (a list of door sensors). In my automation I want to check in a condition, if all sensors are closed - only then should the automation run. The problem is, that the input is actually a key-value pair (entity_id: ['sensor.e08_wds']
). How can I get the list of entities in my template condition?
blueprint:
input:
contacts:
description: If any of the given contacts is on, the target wont turn on.
default: []
selector:
target: {}
variables:
contacts: !input contacts
condition:
- condition: and
conditions:
# other conditions...
- "{{ expand(contacts) | selectattr('state', 'eq', 'on') | list | count == 0 }}"
Debugging the automation, the condition step detail is:
conditions/1
Executed: July 26, 2022 at 10:37:24 PM
Result:
result: true
entities:
- entity_id # should be - sensor.e08_wds
This is how I pass the input to blueprint:
contacts:
entity_id:
- binary_sensor.e08_wds_contact
