I have been trying to figure out how to add multiple rules in node red for the get entities rules array before I call that object. Can someone show me an example?
I use the get entities object to get all objects and then check if it is a light or a switch to turn on or off everything. I call this from multiple flows but there are times I want to exclude one or two items. So I need to override the rules with the array but I am unsure how to do it:
"rules": [
"property": "entity_id",
"logic": "does_not_include",
"value": "switch.front_door_outside_light_switch",
"valueType": "str"
"value": "switch.alarm_plug_on_off",
"valueType": "str"
I tried something like this in a function:
var arrules = ["entity_id","does_not_include","switch.alarm_plug_on_off","str"]
msg.payload = {"rules":arrules}
return msg;
but the message just comes back with “”[0]" must be of type object".
I also want to pass in multiple arrays and unsure how to do that.
Thanks, J
