Get entity friendly name in function
I have a function in which i want to check the status of a binary sensor, but also get the friendly name of that sensor. I can’t find any way to reference the entity.
I do have the entity ID i can pass, but not sure of the command required in order to query for the attribute. Any guidance or link to reference documentation, i’ve been searching for 2 hours.
I was hoping it’d be as simple as get.object[‘obj-id’].attributes.friendly_name
Many thanks in advance
https://zachowj.github.io/node-red-contrib-home-assistant-websocket/node/config-server.html#context-example
Thank you, but that doesn’t give me path to friendly name?
const entity = configCtx.states["switch.my_switch"];
msg.payload = entity.attributes.friendly_name;
return msg;
Thank you @Kermit - That worked as expected.
For my benefit, is there somewhere documented you were able to find the tree entitiy.attributes.friendly_name - I am curious how you knew this was the location?
Put a debug node on and set it to the complete message as output.
Then look at the captured output and find you data.
To the right of it should be 3 smal icons.
One of these (I think it is the middle one) will copy the path to your clipboard.
I’m sharing something weird that happened around getting the friendly_name because it took me a bit to resolve. I had everything working and then suddenly started getting the following error when trying to retrieve states in the function node
"TypeError: Cannot read properties of undefined (reading 'states')"
“Get Friendly Device Name” function:
const haCtx = global.get("homeassistant");
const configCtx = haCtx.homeAssistant;
const entity = configCtx.states[msg.topic];
msg.displayName = entity.attributes.friendly_name;
return msg;
The problem ended up being my HA server name in Node-Red. I had “Home Assistant Pi” as my server name and for some reason the script above worked fine, until it didn’t. The issue ended up being a Node-Red server name mismatch with the script. I ended up changing my server name to homeassistant and the line above to ...haCtx.homeassistant; and everything started working again.
I’m baffled because I didn’t haven’t my server in a year or so. Anyway, hopefully this helps the next person.
