Get every nth element from weather service response
I am trying to get the temperature from the output of weather.get_forecast every third element.
Temperature is not changing so much, so I would like to safe some space on my display :wink:
I tried to use looping using a variable, according to this post: Counting simple variable in jinja (loop), but I don’t get the counter implemented in the .attribute.forecast[ ] the way it works correctly.
At the moment I am using this template to display the temperature of the next three hours
 {% for state in states.sensor.weather_forecast_hourly.attributes.forecast[1:4] -%}
        {{ as_timestamp(state.datetime)| timestamp_custom("%H") }}h;{{ state.temperature| round(0) }}°#
        {%- endfor %}
Great idea … I constructed this to show every 2nd one…possibly some of the guru’s have another idea :slight_smile:
 {% for s in range(0,states.sensor.weather_forecast_hourly.attributes.forecast|length) -%}
 {% if s  | int % 2 == 0 %}
{{ states.sensor.weather_forecast_hourly.attributes.forecast[s].temperature }}
{% endif %}
{%- endfor %}
It is working, thank you!
i changed the line states.sensor.weather_forecast_hourly.attributes.forecast|length’ to an integer to limit the number output values and added some more attributes to the output.
I really enjoy this community - 1h and some smart person has a solution and nobody tells you ā€œweather is stupidā€ or ā€œyou don’t need temperature, you need insert something totally differentā€
