Since the recent update changes have been made to the weather, my node red automation which got the weather forecast for tomorrow has broken,
Historically the weather entity used to have an attribute array you could look at “msg.payload.attributes.forecast[1]” for example to get tomorrows data, but that’s now not available even though on the weather entity in HA you can see the next 5 days worth of weather.
No problem, I’ll move over to the newly created weather.get_forecasts, I look up the data on the wiki, and seems simple enough, I test in the services developer section, and it works wonderfully:
But for some reason, in node red, the service when called only gives back gibberish, it returns a string of numbers rather than anything useful, for the life of me I can’t figure it out and my googlefu and searching don’t return anything I could see that would work, anyone have any idea’s please?
[{"id":"a4cb3b18f81283f0","type":"inject","z":"4fbb0f02.0e5f6","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":1660,"wires":[["043feebdb88ee1a0"]]},{"id":"043feebdb88ee1a0","type":"api-call-service","z":"4fbb0f02.0e5f6","name":"weather","server":"b3a3253e.d12568","version":5,"debugenabled":true,"domain":"weather","service":"get_forecasts","areaId":[],"deviceId":[],"entityId":["weather.home"],"data":"{\"type\":\"daily\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":340,"y":1660,"wires":[["5389b898e37db2b8"]]},{"id":"5389b898e37db2b8","type":"debug","z":"4fbb0f02.0e5f6","name":"debug 12","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":520,"y":1660,"wires":[]},{"id":"b3a3253e.d12568","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
TIA
