Get HACS add on log does not contain any instructions
I installed the get hacs add on, rebooted HA, but I’m not seeing any instructions in the log. This is the complete dump:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[15:31:05] INFO: ------------------------------------
[15:31:05] INFO: Starting HACS download...
[15:31:05] INFO: Channel: current
Connecting to raw.githubusercontent.com (185.199.111.133:443)
saving to './get-hacs'
get-hacs             100% |********************************|  4990  0:00:00 ETA
'./get-hacs' saved
INFO: Trying to find the correct directory...
INFO: Found Home Assistant configuration directory at '/homeassistant'
INFO: Changing to the custom_components directory...
INFO: Downloading HACS
Connecting to github.com (20.26.156.215:443)
Connecting to objects.githubusercontent.com (185.199.108.133:443)
saving to 'hacs.zip'
hacs.zip              37% |************                    | 6204k  0:00:01 ETA
hacs.zip             100% |********************************| 16.0M  0:00:00 ETA
'hacs.zip' saved
INFO: Creating HACS directory...
INFO: Unpacking HACS...
INFO: Verifying versions
INFO: Current version is 2024.12.1, minimum version is 2024.4.1
INFO: Removing HACS zip file...
INFO: Installation complete.
INFO: Remember to restart Home Assistant before you configure it
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[15:36:50] INFO: ------------------------------------
[15:36:50] INFO: Starting HACS download...
[15:36:50] INFO: Channel: current
'./get-hacs' saved
hacs.zip              84% |***************************     | 13.6M  0:00:00 ETA
'hacs.zip' saved
WARN: HACS directory already exist, cleaning up...
 Live
Hello Tom Chambers,
Now restart Home assistant to load the integration internally and then go into integrations and add HACS…
Open your Home Assistant instance and show your integrations.
Hi
Did you solve this ?
Im getting brain dead trying to instal HACS
The instructions work until I need to assign HACS to an area. I cant find HCS anywhere to complete the installation or configuration.
Any gotchas deeper in the instal or am I doomed ?
Hi . I just guided back to request authentication on github
