Get Home Assistant to "click" a link? [Solved]
Afternoon All,
Is there a way to get HA to “click” on a link?
I am using Eventghost’s webserver which allows you to create an HTML file with links that can trigger events (on the PC).
Is there a way to get HA to “click” these links (either by a switch, automation, anything really).
Out of totally ignorance I tried using rest_commands (as that was what I used with unified remote) however clearly this is the incorrect route as it does not work. Tried post btw.
Ended up using Shell_Command with CURL. Works a treat.
