I have created an input_number as follows in configuration.yaml:
input_number:
harmony_volume:
initial: 1
min: 1
max: 99
step: 1
and added it to the UI:
- title: Music
cards:
- type: entities
entities:
- entity: input_number.harmony_volume
It is shown great:
Now, I have a: “events: state” node in Node-RED:
Server: Home Assistant
Entity ID: input_number.harmony_volume
which indeed fired when the input_number slider is changed in the UI, but the problem is that it is fired only when I release the slider (touch up) and not while dragging.
I would like a continuous onChange event triggered to: “Node-RED”.
I guess it is possible using Home Assistant Automation (not sure how) but I wonder if there is a simpler solution based on what I have already done.
Thank you very much in advance
