Play with this in the template editor, and with reference to tools like JSON Viewer Online Best and Free
What a horribly convoluted data structure that is!
First line is the JSON response minified to a single line.
Second line pulls out the first elevation item.
Third and fourth lines get the data you want from that.
{% set value_json = {"name":"ns1:timeSeriesResponseType","declaredType":"org.cuahsi.waterml.TimeSeriesResponseType","scope":"javax.xml.bind.JAXBElement$GlobalScope","value":{"queryInfo":{"queryURL":"http://waterservices.usgs.gov/nwis/dv/format=json&sites=02187010","criteria":{"locationParam":"[ALL:02187010]","variableParam":"ALL","parameter":[]},"note":[{"value":"[ALL:02187010]","title":"filter:sites"},{"value":"[mode=LATEST, modifiedSince=null]","title":"filter:timeRange"},{"value":"methodIds=[ALL]","title":"filter:methodId"},{"value":"2024-05-03T14:13:34.149Z","title":"requestDT"},{"value":"539eb750-0957-11ef-9788-2cea7f58f5ca","title":"requestId"},{"value":"Provisional data are subject to revision. Go to http://waterdata.usgs.gov/nwis/help/?provisional for more information.","title":"disclaimer"},{"value":"vaas01","title":"server"}]},"timeSeries":[{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00021","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807074,"default":true}],"variableName":"Temperature, air, °F","variableDescription":"Temperature, air, degrees Fahrenheit","valueType":"Derived Value","unit":{"unitCode":"deg F"},"options":{"option":[{"value":"Maximum","name":"Statistic","optionCode":"00001"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807074"},"values":[{"value":[{"value":"80.9","qualifiers":["P"],"dateTime":"2024-05-01T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126700}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00021:00001"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00021","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807074,"default":true}],"variableName":"Temperature, air, °F","variableDescription":"Temperature, air, degrees Fahrenheit","valueType":"Derived Value","unit":{"unitCode":"deg F"},"options":{"option":[{"value":"Minimum","name":"Statistic","optionCode":"00002"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807074"},"values":[{"value":[{"value":"60.8","qualifiers":["P"],"dateTime":"2024-05-01T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126701}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00021:00002"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00021","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807074,"default":true}],"variableName":"Temperature, air, °F","variableDescription":"Temperature, air, degrees Fahrenheit","valueType":"Derived Value","unit":{"unitCode":"deg F"},"options":{"option":[{"value":"Mean","name":"Statistic","optionCode":"00003"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807074"},"values":[{"value":[{"value":"70.1","qualifiers":["P"],"dateTime":"2024-05-01T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126702}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00021:00003"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00035","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807109,"default":true}],"variableName":"Wind speed, mph","variableDescription":"Wind speed, miles per hour","valueType":"Derived Value","unit":{"unitCode":"mph"},"options":{"option":[{"value":"Maximum","name":"Statistic","optionCode":"00001"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807109"},"values":[{"value":[{"value":"8.1","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126704}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00035:00001"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00035","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807109,"default":true}],"variableName":"Wind speed, mph","variableDescription":"Wind speed, miles per hour","valueType":"Derived Value","unit":{"unitCode":"mph"},"options":{"option":[{"value":"Minimum","name":"Statistic","optionCode":"00002"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807109"},"values":[{"value":[{"value":"0.2","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126705}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00035:00002"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00035","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807109,"default":true}],"variableName":"Wind speed, mph","variableDescription":"Wind speed, miles per hour","valueType":"Derived Value","unit":{"unitCode":"mph"},"options":{"option":[{"value":"Mean","name":"Statistic","optionCode":"00003"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807109"},"values":[{"value":[{"value":"2.7","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126706}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00035:00003"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00036","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807110,"default":true}],"variableName":"Wind direction, degrees clockwise from north","variableDescription":"Wind direction, degrees clockwise from true north","valueType":"Derived Value","unit":{"unitCode":"Deg"},"options":{"option":[{"value":"Maximum","name":"Statistic","optionCode":"00001"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807110"},"values":[{"value":[{"value":"356","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126707}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00036:00001"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00036","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807110,"default":true}],"variableName":"Wind direction, degrees clockwise from north","variableDescription":"Wind direction, degrees clockwise from true north","valueType":"Derived Value","unit":{"unitCode":"Deg"},"options":{"option":[{"value":"Minimum","name":"Statistic","optionCode":"00002"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807110"},"values":[{"value":[{"value":"0","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126708}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00036:00002"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00036","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807110,"default":true}],"variableName":"Wind direction, degrees clockwise from north","variableDescription":"Wind direction, degrees clockwise from true north","valueType":"Derived Value","unit":{"unitCode":"Deg"},"options":{"option":[{"value":"Mean","name":"Statistic","optionCode":"00003"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807110"},"values":[{"value":[{"value":"173","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126709}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00036:00003"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00045","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807140,"default":true}],"variableName":"Precipitation, total, in","variableDescription":"Precipitation, total, inches","valueType":"Derived Value","unit":{"unitCode":"in"},"options":{"option":[{"value":"Sum","name":"Statistic","optionCode":"00006"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807140"},"values":[{"value":[{"value":"0.00","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126703}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00045:00006"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00052","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807168,"default":true}],"variableName":"Relative humidity, percent","variableDescription":"Relative humidity, percent","valueType":"Derived Value","unit":{"unitCode":"%"},"options":{"option":[{"value":"Maximum","name":"Statistic","optionCode":"00001"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807168"},"values":[{"value":[{"value":"96.1","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126697}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00052:00001"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00052","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807168,"default":true}],"variableName":"Relative humidity, percent","variableDescription":"Relative humidity, percent","valueType":"Derived Value","unit":{"unitCode":"%"},"options":{"option":[{"value":"Minimum","name":"Statistic","optionCode":"00002"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807168"},"values":[{"value":[{"value":"33.5","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126698}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00052:00002"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00052","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807168,"default":true}],"variableName":"Relative humidity, percent","variableDescription":"Relative humidity, percent","valueType":"Derived Value","unit":{"unitCode":"%"},"options":{"option":[{"value":"Mean","name":"Statistic","optionCode":"00003"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807168"},"values":[{"value":[{"value":"69.4","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126699}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00052:00003"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00062","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807199,"default":true}],"variableName":"Elevation of reservoir water surface above datum, ft","variableDescription":"Elevation of reservoir water surface above datum, feet","valueType":"Derived Value","unit":{"unitCode":"ft"},"options":{"option":[{"value":"Maximum","name":"Statistic","optionCode":"00001"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807199"},"values":[{"value":[{"value":"660.15","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126710}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00062:00001"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00062","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807199,"default":true}],"variableName":"Elevation of reservoir water surface above datum, ft","variableDescription":"Elevation of reservoir water surface above datum, feet","valueType":"Derived Value","unit":{"unitCode":"ft"},"options":{"option":[{"value":"Minimum","name":"Statistic","optionCode":"00002"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807199"},"values":[{"value":[{"value":"660.05","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126711}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00062:00002"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"00062","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":45807199,"default":true}],"variableName":"Elevation of reservoir water surface above datum, ft","variableDescription":"Elevation of reservoir water surface above datum, feet","valueType":"Derived Value","unit":{"unitCode":"ft"},"options":{"option":[{"value":"Mean","name":"Statistic","optionCode":"00003"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"45807199"},"values":[{"value":[{"value":"660.11","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126712}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:00062:00003"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"62608","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":51413493,"default":true}],"variableName":"Total solar radiation (direct + diffuse radiation on a horizontal surface), watts/m²","variableDescription":"Total solar radiation (direct + diffuse radiation on a horizontal surface), watts per square meter","valueType":"Derived Value","unit":{"unitCode":"W/m2"},"options":{"option":[{"value":"Maximum","name":"Statistic","optionCode":"00001"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"51413493"},"values":[{"value":[{"value":"761","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126713}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:62608:00001"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"62608","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":51413493,"default":true}],"variableName":"Total solar radiation (direct + diffuse radiation on a horizontal surface), watts/m²","variableDescription":"Total solar radiation (direct + diffuse radiation on a horizontal surface), watts per square meter","valueType":"Derived Value","unit":{"unitCode":"W/m2"},"options":{"option":[{"value":"Minimum","name":"Statistic","optionCode":"00002"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"51413493"},"values":[{"value":[{"value":"10","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126714}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:62608:00002"},{"sourceInfo":{"siteName":"HARTWELL LAKE NEAR ANDERSON, SC","siteCode":[{"value":"02187010","network":"NWIS","agencyCode":"USGS"}],"timeZoneInfo":{"defaultTimeZone":{"zoneOffset":"-05:00","zoneAbbreviation":"EST"},"daylightSavingsTimeZone":{"zoneOffset":"-04:00","zoneAbbreviation":"EDT"},"siteUsesDaylightSavingsTime":true},"geoLocation":{"geogLocation":{"srs":"EPSG:4326","latitude":34.5083333,"longitude":-82.8552778},"localSiteXY":[]},"note":[],"siteType":[],"siteProperty":[{"value":"LK","name":"siteTypeCd"},{"value":"03060103","name":"hucCd"},{"value":"45","name":"stateCd"},{"value":"45007","name":"countyCd"}]},"variable":{"variableCode":[{"value":"62608","network":"NWIS","vocabulary":"NWIS:UnitValues","variableID":51413493,"default":true}],"variableName":"Total solar radiation (direct + diffuse radiation on a horizontal surface), watts/m²","variableDescription":"Total solar radiation (direct + diffuse radiation on a horizontal surface), watts per square meter","valueType":"Derived Value","unit":{"unitCode":"W/m2"},"options":{"option":[{"value":"Mean","name":"Statistic","optionCode":"00003"}]},"note":[],"noDataValue":-999999,"variableProperty":[],"oid":"51413493"},"values":[{"value":[{"value":"207","qualifiers":["P"],"dateTime":"2024-05-02T00:00:00.000"}],"qualifier":[{"qualifierCode":"P","qualifierDescription":"Provisional data subject to revision.","qualifierID":0,"network":"NWIS","vocabulary":"uv_rmk_cd"}],"qualityControlLevel":[],"method":[{"methodDescription":"","methodID":126715}],"source":[],"offset":[],"sample":[],"censorCode":[]}],"name":"USGS:02187010:62608:00003"}]},"nil":false,"globalScope":true,"typeSubstituted":false} %}
{% set i = value_json['value']['timeSeries']|selectattr('variable.variableDescription','contains','Elevation')|list|first %}
Timestamp: {{ i['values'][0]['value'][0]['dateTime'] }}
Elevation: {{ i['values'][0]['value'][0]['value'] }}
So you could do this for the elevation sensor:
value_template: >
Better still, use the RESTful integration to get both from a single call, discarding everything else:
rest:
- scan_interval: 3600
resource: https://waterservices.usgs.gov/nwis/dv/?format=json&sites=02187010
- name: "Lake elevation"
value_template: >
unit_of_measurement: 'ft'
- name: "Lake elevation timestamp"
value_template: >
Heh. I’m getting quite good at this:
