mr_aleks
(mr_aleks)
January 16, 2024, 8:43pm
1
Hi everybody.
How can I get the last change the door sensor as a timestamp to calculate how much has passed since that moment?
I need this value:
I’m trying to just get timestamp the last modified , but I can’t seem to get it:
{{ (as_timestamp(now()) - as_timestamp(states.binary_sensor.0x00158d00019943cf_contact.last_changed ) | timestamp_custom("%Hh %Mm", false)}}
when testing the template, I get this:
TemplateSyntaxError: expected token ',', got 'ontact'
My sensor
tom_l
January 17, 2024, 12:58am
2
Your binary sensor entity id starts with a number. This is problematic for Home Assistant (and Python variables in general). You need to use square bracket notation in this case, see: https://www.home-assistant.io/docs/configuration/templating/#entity_id-that-begins-with-a-number
So like this:
{{ (as_timestamp(now()) - as_timestamp(states.binary_sensor['0x00158d00019943cf_contact'].last_changed ) | timestamp_custom("%Hh %Mm", false)}}
A better idea would be to rename your entity id to something meaningful, like binary_sensor.front_door_contact
mr_aleks
(mr_aleks)
January 17, 2024, 6:35am
3
Thank you very much, yesterday I tried to write in various syntax but it didn’t work. This is what I needed!
You made a mistake in the parenthesis, you need a second closing one after .last_changed.
tom_l
January 17, 2024, 6:43am
4
Not me I just copied your original template and added the square brackets.
