Get Life360 to show driving
Those errors are unfortunately not uncommon. Unless they are completely preventing updating of the device_trackers it’s not usually a problem. There are a couple of config options you can set to filter most of those out.
But getting back to the original issue, has it been resolved yet?
I got exactly the same issue here. When i’m driving my home assistant shows me as moving, not as driving.
Is there any update on this? Perhaps I can assist in providing logs or configs? I’m also using the Life360 Hass.io integration.
What is your life360 HA configuration?
platform: life360
interval_seconds: 30
prefix: life360
#username: !secret email_rick
#password: !secret life360_password
show_as_state: driving, moving
driving_speed: 10
max_gps_accuracy: 300
consider_home: 180
filename: life360.conf
add_zones: false
That is not a correct configuration. See:
Changed it to this, now it should be correct. I have a spliced up configuration, that’s why I need to define a platform.
platform: life360
prefix: life360
show_as_state:
  - driving
  - moving
driving_speed: 20
add_zones: false
Are you reading that page? That is not correct.
It should be:
life360:
  driving_speed: 20
  show_as_state:
    - driving
    - moving
Also, it appears that maybe you once used the custom integration. If so, you need to remove all remnants of it (i.e., there should be no Python files, etc. anywhere in your config directly – especially in custom_components – that has anything to do with the old custom integration, other than the YAML configuration entry in the new format.)
life360:
  driving_speed: 20
  show_as_state:
    - driving
    - moving
gives me the following error:
And that’s (I think) because my configuration is spliced up, please correct me if I’m wrong. I’m no pro at home assistant yet, and only learning here.
I did indeed use the old integration but made sure that every remnant of that is gone.
You are putting it under device_tracker:. It doesn’t belong there.
EDIT: If you need to, read up more on:
The life360 key is a “top level” key, and needs to be at the “same level” as homeassistant, sensor, etc.
Alright, I got a valid configuration now. I created a new yaml file in my integrations folder, called it life360, moved above mentioned config to that file, everything checks out now.
EDIT:
I didn’t know about the top level key. I thought I could create a life360 folder in my entities folder and have the yaml file in my integrations folder forward to that life360 folder in entities, same as I do for my sensors, for example.
It’s working again! Thanks for your help, learned something again!
Glad you got it working Rick…
Can you post your device_tracker configuration and your life_360 configuration
Mine is…
device_tracker:
  - platform: life360
    interval_seconds: 12
    prefix: life360
    show_as_state: [driving, moving]
    driving_speed: 10
    max_gps_accuracy: 50
    consider_home: 180
    max_update_wait:
      minutes: 45
    add_zones: true
    zone_interval:
    new_device_defaults:
      track_new_devices: true
and
life360:
  accounts:
    - username: !secret life360_username
  # Only track Members that are in these Circles.
  circles:
    include: Family
It seems you have used, and are maybe still using, the original custom life360 integration. That is no longer supported. You need to change to using the standard life360 integration.
See the migration instructions here and the doc page for the standard integration here.
Frankly is been so long that Ive forgotten how I set it up… that said I’ll do a migration…
Thanks All!
-Aaron
Sure, keep in mind that I do use the new integration, so I only have a life360.yaml configuration file, I don’t have a device tracker file anymore.
life360:
  driving_speed: 15
  interval_seconds: 10
  max_gps_accuracy: 200
  show_as_state:
    - driving
    - moving
This file is located in my integrations folder, it would be the same if you add this to you configuration.yaml
The life360 integration creates a file in your config folder called life360.conf. This file holds your login credentials and API key.
Not anymore. This is noted in the migration instructions. The credentials are now stored in .storage/core.config_entries.
