Get no entity with uln2003 Motor Driver -solved-
I’m stuck with a very big problem. Namely, I ordered a 28BYJ-48 Stepper Motor and ULN2003 Stepper Motor Driver, this should actually switch the switch of my heater control… I plugged the ULN2003 into a D1 Mini…
here the yaml
esphome:
esp8266:
  board: d1_mini
mqtt:
  broker: 192.168.178.77
  username: broker
  password: MQTT_PASSWORD
ota:
  password: "OTA_PASSWORD"
wifi:
  ssid: "kleine geile Nonne"
  password: "SSID_PASSWORD"
  fast_connect: true
  ap:
    ssid: "Heizungssteuerung"
    password: "AP_PASSWORD"
web_server:
  port: 80
logger:
api:
  encryption:
    key: "API_KEY"
  services:
    - service: control_stepper
      variables:
        target: int
      then:
        - stepper.set_target:
            target: !lambda 'return target;'
captive_portal:
stepper:
  - platform: uln2003
    sleep_when_done: False
    pin_a: D5
    pin_b: D6
    pin_c: D7
    pin_d: D8
    max_speed: 250 steps/s
    step_mode: FULL_STEP
    acceleration: inf
    deceleration: inf
in the configuration.yaml
input_number:
stepper_control:
   initial: 0
   min: -1000
   max: 1000
   step: 1
   mode: slider
 and last in the automations.yaml alias:
-   alias: Write stepper Value to ESP
  - platform: state
    entity_id: input_number.stepper_control
  - service: esphome.stepper_control_stepper
    data_template:
      my_stepper: '{{ trigger.to_state.state | int }}'
no matter what I do, the ULN does not appear under the entities. I thought the D1mini was damaged and fortunately I had a second one there… Even there, it doesn’t show up. Neither in MQTT broker, nor in ESPHome. Only the status of the D1 Mini and firmware. It should actually appear at least as a device that is not connected if the connections are wrong I’m getting desperate, I don’t know what to do anymore. It can’t be the ULN2003, the motor was successfully controlled with a demo sketch flashed with Arduino IDE
Please edit your post and correctly format your esp and home assistant configuration for the forum.
Please also include the serial logs from the esp device.
There is nothing in your configuration that would create an entity in HA, as explained in the note at the top in the documentation.
You can define a template switch that would then tell the stepper motor what to do.
Problem is solved…
If you could share the resolution, you might be able to help others in the future?
What was your solution? I’m struggling with the same thing…
