carltonb
(Carlton Brooks)
August 27, 2020, 8:01pm
42
Thanks for the quick response.
If you don’t mind a few more questions
In the sensor you have the following…
- platform: rest
resource: http://192.168.1.2:8123/api/hassio/addons/a0d7b954_adguard/info
In the text you say
For example this adguard add-on URL ends in /hassio/addon/a0d7b954_adguard
Notice the url… /hassio/addons/ versus /hassio/addon/
My url for adguard is /hassio/addon/
Which do I use for the sensor url?
Also mine does not have the /api/ (but I left it in the url)
carltonb
silvrr
August 27, 2020, 9:48pm
43
Interesting.
The URL when i go to an add-on says addon
while my sensor says addons
I wonder if there was a change at some point but they both still work. Not sure on this one. I would go addons
as I know that currently works for the rest api. The only thing you need to pull from the URL on the supervisor page is the add-on name (ie. a0d7b954_adguard)
the /api/
comes from the developer docs.
filikun
(Filikun)
September 1, 2020, 7:56am
44
What typo was that? I have the exact same problem
EDIT: Found it myself. It’s /api/hassio/addons not /api/hassio/addon. The later did not work for me.
since today; this sensor is broken? Prevviously it compared the installed adoon vs addon available, and it gave an integer back when a new version was available
not it prompts that all my addons are outdated?
- platform: command_line
name: Supervisor Addon updates
command: 'curl http://supervisor/supervisor/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)" | jq ''{"newest_version":.data.version_latest,"current_version":.data.version,"addons":[.data.addons[] | select(.version != .installed)]}'''
value_template: "{{ value_json.addons | length }}"
scan_interval: 1440
json_attributes:
- newest_version
- current_version
- addons
output it gives : 5
newest_version: 2020.10.0
current_version: 2020.10.0
addons:
- name: Samba share
slug: core_samba
description: Expose Home Assistant folders with SMB/CIFS
state: started
version: 9.3.0
version_latest: 9.3.0
update_available: false
repository: core
icon: true
logo: true
- name: SSH & Web Terminal
slug: a0d7b954_ssh
description: SSH & Web Terminal access to your Home Assistant instance
state: started
version: 7.6.0
version_latest: 7.6.0
repository: a0d7b954
icon: true
logo: true
- name: deCONZ
slug: core_deconz
description: Control a Zigbee network with ConBee or RaspBee by Dresden Elektronik
state: started
version: 6.4.1
version_latest: 6.4.1
repository: core
icon: true
logo: true
- name: Check Home Assistant configuration
slug: core_check_config
description: Check current Home Assistant configuration against a new version
state: stopped
version: 3.6.0
version_latest: 3.6.0
repository: core
icon: true
logo: true
- name: motionEye
slug: a0d7b954_motioneye
description: 'Simple, elegant and feature-rich CCTV/NVR for your cameras'
state: started
version: 0.10.2
version_latest: 0.10.2
icon: true
logo: true
friendly_name: Supervisor Addon updates
any idea what i need to change?
silvrr
October 28, 2020, 4:47pm
46
@pergola.fabio you likely want to ask your question in the thread linked below. This thread doesn’t utilize the method you posted.
will do , but no idea anyway?
Looks like they changed the data model of the API response and it broke. I figured it out, will update on the thread.
poudenes
(Poudenes)
January 25, 2021, 7:09pm
50
Sometimes is better to read the change log. Without reading it you don’t know whats new, or whats changed. It would be nice to have in every AddOn automatically a sensor created that shows a “Update available”
poudenes
(Poudenes)
January 28, 2021, 8:25am
51
Hi All,
Will it be possible to change the value_template to something like this:
{% if is_state(version < version_latest) %} on
{% else %} off
{% endif %}
When the current version is lower then the latest one, the sensor will be ON
With this state you can create other automations around it.
- platform: rest
resource: !secret supervisor_addon_1
name: "Adguard Version Update"
value_template: "{{ value_json.data.state }}"
scan_interval: 14400
headers:
Authorization: !secret longlifetoken
Content-Type: application/json
json_attributes_path: "$.data"
json_attributes:
- version
- version_latest
poudenes:
sure, but since it is always dangerous comparing strings like that, why not simply use
{{ version != version_latest }}
of course you’d need to use a {% set version = xxx %}
and same for version_latest
o heck, wait, I now realize you meant this to be in the rest sensor. I wrote my answer to be a separate binary_sensor.
my pardon
that would be my preferred way though, keeping the main sensor as is, and create some (binary) template sensors off off that.
like this for the supervisor updates:
addon_updates_available:
friendly_name: Addon update available
value_template: >
{{states('sensor.supervisor_updates')|int != 0}}
attribute_templates:
Updates: >
{{states('sensor.supervisor_updates') if
states('sensor.supervisor_updates')|int != 0 else 'No'}} update{{'s' if
states('sensor.supervisor_updates')|int != 1 else ''}} available
This blueprint might help:
Based on feedback from fellow forum user @MGHollander , I’ve updated the blueprint that will notify you when an addon update becomes available.
The original blueprint can be found here .
Description
This blueprint will send you an update when an addon update is available. An example of such update can be found below:
[IMG_38278E3055B5-1]
Features
Sends the notification when the update is available.
Clicking on the notification brings you straight to the information page of the addon, allowing…
