Given that you have access to spotcast’s source-code, you are free to modify it to return whatever information you want in whatever format you need.
I don’t use spotcast so I will leave it to someone else to help you modify it. However, if I did use it, I wouldn’t change its code but simply create a python_script to extract the desired names and assign them to the input_select.
I believe the python_script will be something like this (which is untested and may require modifications):
devices = hass.states.get('sensor.chromecast_devices').attributes['devices_json']
options = []
for d in devices:
options.append(d['name'])
if len(options) > 0:
service_data = {'entity_id': 'input_select.spotcast_select', 'options': options}
hass.services.call('input_select', 'set_options', service_data)
It gets the devices_json attribute from sensor.chromecast_devices.
It creates an empty list called options.
It loops through the devices_json list and extracts the value of the key called “name”. It appends this value to the options list.
It checks if the options list contains items.
It creates a JSON string, called service_data, containing all the information needed for the set_options service.
Finally, it calls input_select.set_options using service_data.
If you don’t know how to use the python_script integration, here’s the documentation and feel free to ask me any questions to help you get it running.
EDIT
Replaced original, defective code with new, functional code.
File "/usr/src/homeassistant/homeassistant/components/python_script/__init__.py", line 196, in execute
exec(compiled.code, restricted_globals)
File "spotcastinput.py", line 5, in <module>
File "/usr/local/lib/python3.7/site-packages/RestrictedPython/Eval.py", line 35, in default_guarded_getitem
return ob[index]
TypeError: string indices must be integers
Edit:
I can confirm the last 2 lines of your code work, so it must be something in where it parses the data.
Edit 2:
Going to try to see what the output of the devices variable is. Let’s see…
Edit 3:
The error is when it tries to do the loop for d in devices
hmmm strange…
Edit 4:
The error is in the data spotcast returns. If I take away the devices = and replace it with just this
