Get run_duration from ESPHome Sprinkler
Hi, I would display the next run_duration from my esp_home sprinkler valve in the Frontend, but can not find any attribute or entity.
Does anybody has an Idea to get this Information?
As in the value you have set ready to go the next time it runs…?
I have these:
Which come from code like this in my ESPhome config:
    name: Retic Front Garden Time
    min_value: 1
    max_value: 30
    step: 1
    unit_of_measurement: Min
    icon: "mdi:timer-outline"
    mode: box # Defines how the number should be displayed in the UI
    lambda: "return id(retic_controller).valve_run_duration(0);"
    set_action:
      - sprinkler.set_valve_run_duration:
          valve_number: 0
          run_duration: !lambda 'return x;'
I set the run_duration with an automation script, using HASmartIrrigation.
This is working fine. But I can not see in the Frontend, how long the valvue has to run on the next Duration.
So you mean while the duration is counting down?
No i mean, before i start the sprinkler process. I want have to see, how long the sprinkler has to run on the next duration.
Well that is exactly what I posted above… you haven’t shown any of your code so it’s impossible to know why you don’t have entities the same as mine.
You did not read the duration from esphome. You only write you prefered duration by submit a value to set_valve_run_duration action.
But I want only read the next duration. I did not want to set the duration.
Here you can see my script, but I think this can not solve my question :wink:
esphome:
  friendly_name: Gartenbewässerung
esp8266:
  board: d1_mini
wifi:
  ssid: !secret wifi_ssid_smarthome
  password: !secret wifi_password_smarthome
  # Optional manual IP
  manual_ip:
    static_ip: xxx.xxx.xxx.xxx
    gateway: xxx.xxx.xxx.xxx
    subnet: xxx.xxx.xxx.xxx
api:
  services:
    - service: set_valve_run_duration
      variables:
        duration: int
        valve: int
      then:
            run_duration: !lambda 'return duration;'
            valve_number: !lambda 'return valve;'
    - service: start_full_cycle
      then:
        - sprinkler.start_full_cycle: lawn_sprinkler_ctrlr
    - service: start_single_valve
      variables:
        valve: int
      then:
        - sprinkler.start_single_valve:
    - service: next_valve
      then:
        - sprinkler.next_valve: lawn_sprinkler_ctrlr
    - service: previous_valve
      then:
        - sprinkler.previous_valve: lawn_sprinkler_ctrlr
    - service: shutdown
      then:
        - sprinkler.shutdown: lawn_sprinkler_ctrlr
    - service: pause
      then:
        - sprinkler.pause: lawn_sprinkler_ctrlr
    - service: resume
      then:
        - sprinkler.resume: lawn_sprinkler_ctrlr
    - service: resume_or_full_cycle
      then:
        - sprinkler.resume_or_start_full_cycle: lawn_sprinkler_ctrlr
    - service: repeat_2
      then:
        - sprinkler.set_repeat:
            repeat: 2  # would run two cycles
    - service: repeat_3
      then:
            repeat: 3  # would run three cycles
ota:
  - platform: esphome
# define i2c device
# for an ESP8266 SDA is D2 and goes to Arduino's A4
#                SCL is D1 and goes to Arduino's A5
i2c:
logger:
  level: DEBUG
external_components:
  - source: github://glmnet/esphome@ape-external-component
    components: [arduino_port_expander]
arduino_port_expander:
  address: 0x08
  analog_reference: DEFAULT
output:
  - platform: gpio
    pin:
      arduino_port_expander: ape
      number: 9
      mode:
        output: True
    inverted: true
  - platform: gpio
    pin:
      number: 8
      mode:
        output: True
    inverted: true
  - platform: gpio
    pin:
      number: 7
      mode:
        output: True
    inverted: true
  - platform: gpio
    pin:
      number: 6
      mode:
        output: True
    inverted: true
  - platform: gpio
    pin:
      number: 5
      mode:
        output: True
    inverted: true
  - platform: gpio
    pin:
      number: 4
      mode:
        output: True
    inverted: true
  - platform: gpio
    pin:
      number: 3
      mode:
        output: True
    inverted: true
  - platform: gpio
    pin:
      number: 2
      mode:
        output: True
    inverted: true
switch:
  - platform: output
    output: relay_1
  - platform: output
    output: relay_2
  - platform: output
    name: Rasen vor Pool
    output: relay_3
  - platform: output
    name: Beet Gross Terrasse
    output: relay_4
  - platform: output
    name: Beet Klein Terrasse
    output: relay_5
  - platform: output
    output: relay_6
  - platform: output
    output: relay_7
  - platform: output
    output: relay_8
sprinkler:
  - id: lawn_sprinkler_ctrlr
    main_switch: "Rasensprenger"
    auto_advance_switch: "Rasensprenger Auto Advance"
    reverse_switch: "Rasensprenger Umkehren"
    valve_open_delay: 5s
    valves:
      - valve_switch: "Rasen vor Pool 1"
        enable_switch: "Rasen vor Pool aktivieren"
        run_duration: 1800s
        valve_switch_id: relais_rasen_vor_pool
      - valve_switch: "Rasen Kinder 2"
        enable_switch: "Rasen Kinder aktivieren"
        run_duration: 900s
        valve_switch_id: relais_rasen_kinder
  - id: garden_sprinkler_ctrlr
    main_switch: "Beet Bewässerung"
    auto_advance_switch: "Beet Bewässerung Auto Advance"
    valves:
      - valve_switch: "Beet Terrasse Gross 3"
        run_duration: 9000s
        valve_switch_id: relais_beet_terrasse_gross
      - valve_switch: "Beet Terrasse Gross 4"
        run_duration: 9000s
        valve_switch_id: relais_beet_terrasse_klein
    name: "Rasenbewässerung läuft noch"
    accuracy_decimals: 0
    unit_of_measurement: Sek
    lambda: "return round(id(lawn_sprinkler_ctrlr).time_remaining_active_valve().value_or(0));"
    name: "Rasenbewässerung Laufzeit gesamt"
    lambda: "return round(id(lawn_sprinkler_ctrlr).total_cycle_time_enabled_incomplete_valves());"
  # - platform: arduino_port_expander
  #   id: analog_input_1_humidity
  #   pin: A6
  #   name: Rasen vor Pool (Bodenfeuchtigkeit)
  #   unit_of_measurement: "%"
  #   device_class: humidity
  #   state_class: measurement
  #   accuracy_decimals: 0
  #   #update_interval: 10s
  #   update_interval: never
  #   filters:
  #     - multiply: 0.004887585532746823069403714565 # x * 1023.0 / 5.0 v
  #     - calibrate_linear:
  #         - 0.95 -> 100
  #         - 2.5 -> 0
  #     - lambda: |
  #         if (x < 0) return 0;
  #         else if (x > 100) return 100;
  #         else return (x);
    pin: A6
    name: Rasen vor Pool (Spannung)
    filters:
  - platform: copy
    source_id: analog_input_1_voltage
    filters:
      - calibrate_linear:
          - 0.95 -> 100
          - 2.5 -> 0
      - lambda: |
          else return (x);
# https://community.home-assistant.io/t/soil-moisture-sensor-output-as-a-percentage/250885/5
  - platform: copy
    name: Rasen vor Pool Test 2 (Bodenfeuchtigkeit)
    filters:
      - median:
          window_size: 7
          send_every: 4
          send_first_at: 1
      - calibrate_linear:
          - 0.95 -> 100
          - 2.5 -> 0
      - lambda: |
          else return (x);
  #   id: analog_input_2_humidity
  #   pin: A7
  #   name: Rasen Kinder (Bodenfeuchtigkeit)
  #   filters:
  #         - 0.95 -> 100
  #         - 2.5 -> 0
  #     - lambda: |
  #         else return (x);
    pin: A7
    name: Rasen Kinder (Spannung)
    filters:
  - platform: copy
    source_id: analog_input_2_voltage
    filters:
      - calibrate_linear:
          - 0.95 -> 100
          - 2.5 -> 0
      - lambda: |
          else return (x);
  #   id: analog_input_3_humidity
  #   pin: A0
  #   name: Eingang 3 Bodenfeuchtigkeit
  #   filters:
  #         - 0.95 -> 100
  #         - 2.5 -> 0
  #     - lambda: |
  #         else return (x);
    pin: A0
    name: Eingang 3 Spannung
    filters:
  - platform: copy
    source_id: analog_input_3_voltage
    filters:
      - calibrate_linear:
          - 0.95 -> 100
          - 2.5 -> 0
      - lambda: |
          else return (x);
  #   id: analog_input_4_humidity
  #   pin: A1
  #   name: Eingang 4 Bodenfeuchtigkeit
  #   filters:
  #         - 0.95 -> 100
  #         - 2.5 -> 0
  #     - lambda: |
  #         else return (x);
    pin: A1
    name: Eingang 4 Spannung
    filters:
  - platform: copy
    source_id: analog_input_4_voltage
    filters:
      - calibrate_linear:
          - 0.95 -> 100
          - 2.5 -> 0
      - lambda: |
          else return (x);
  #   id: analog_input_5_humidity
  #   pin: A2
  #   name: Eingang 5 Bodenfeuchtigkeit
  #   filters:
  #         - 0.95 -> 100
  #         - 2.5 -> 0
  #     - lambda: |
  #         else return (x);
    pin: A2
    name: Eingang 5 Spannung
    filters:
  - platform: copy
    source_id: analog_input_5_voltage
    filters:
      - calibrate_linear:
          - 0.95 -> 100
          - 2.5 -> 0
      - lambda: |
          else return (x);
  #   id: analog_input_6_humidity
  #   pin: A3
  #   name: Eingang 6 Bodenfeuchtigkeit
  #   filters:
  #         - 0.95 -> 100
  #         - 2.5 -> 0
  #     - lambda: |
  #         else return (x);
    pin: A3
    name: Eingang 6 Spannung
    filters:
  - platform: copy
    source_id: analog_input_6_voltage
    filters:
      - calibrate_linear:
          - 0.95 -> 100
          - 2.5 -> 0
      - lambda: |
          else return (x);
interval:
  - interval: 60s
    then:
      # - component.update: analog_input_3_humidity
      # - delay: 1s
      - component.update: analog_input_3_voltage
      - delay: 5s
      # - component.update: analog_input_4_humidity
      # - delay: 1s
      - component.update: analog_input_4_voltage
      - delay: 5s
      # - component.update: analog_input_5_humidity
      # - delay: 1s
      - component.update: analog_input_5_voltage
      - delay: 5s
      # - component.update: analog_input_6_humidity
      # - delay: 1s
      - component.update: analog_input_6_voltage
      - delay: 5s
      # - component.update: analog_input_1_humidity
      # - delay: 1s
      - component.update: analog_input_1_voltage
      - delay: 5s
      # - component.update: analog_input_2_humidity
      # - delay: 1s
      - component.update: analog_input_2_voltage
Sure, but whatever I set it to, will be the next duration.
You could always create template sensors in ESPhome to calculate the time based on your station time and multiplier, then get HA to read that.
