Hi everyone,
Do you know if there is a way to get the window.scrollY distance of a specific lovelace view and dynamically update it to an input number?
Thank you!
Hi everyone,
Thank you!
That would require a client side code running, like a javascript.
HA does not have such javascripts, so you would have to make one yourself.
Do you know how could I integrate that into Home Assistant? Or at least point me in the right direction? I’ve seen something about custom panels… Would that be a viable solution in this case?
Thank you.
I hve no idea.
I guess javascript are powsibl in lovelace cards and it should be possible to transfer the value through a web socket into HA, but how to do it more precisely is not something ai can help with.
