I am able to fetch the states of a single entity using the REST API using http://homeassistant.local:8123/api/states/light.kitchen
. Is it possible to do the same thing via the WebSocket API? I have tried a number of different things, however, it hasn’t worked. I do not want to get the states for all entities at once.
I ran into the same issue because my receiver cannot handle large messages. Did you find some solution?
Best regards
Patrick
I just had a look at the source, I think patching the API so that it accepts a parameter with wildcards should not be too difficult. Probably I give it a try on the weekend.
So… how’d it go? Any luck?
Sorry, I learned that I need to setup a development environment first, before I can patch the few lines of code. I didn’t try that yet due to lack of time. Need to find some …
Looking at the source code of version 2023.11.2 in /components/websocket_api/commands.py this is possible.
There is a (currently) undocumented websocket command of ‘subscribe_entities’.
I’ve tested with the following websocket command it provides state updates for a limited set of entities.
{ “id”: 18,
“type”: “subscribe_entities”,
“entity_ids”: [“switch.test_lamp”]
That is some great news, hopefully documented or officially released soon. Much better than (also) receiving updated from all 8 power plugs and what not. I’ll check this today. Thanks for letting us know!
Hmm… it looks like it has been there for some time now (Mar 12, 2022)
I’ve checked it out. I would be nice if it will get documented soon, as the responses are not fully clear yet.
Tested the normal subscribe_events
and the reported subscribe_entities
and monitored it for one minute.
Method | Messages/min | Data usage/min |
subscribe_events | 584 | 592 kB |
subscribe_entities | 10 | 1.2 kB |
58 times less messages, 493 times less data
Initial response:
"id": 1,
"type": "event",
"event": {
"a": {
"sensor.neocoolcam7_energy_power": {
"s": "79",
"a": {
"unit_of_measurement": "W",
"device_class": "power",
"friendly_name": "NeoCoolcam7 NeoCoolcam7 ENERGY Power"
"c": "01HF3ZMR6SPFK6Z6YA7W184ADG",
"lc": 1699867156.697465
Updates:
"type": "event",
"event": {
"c": {
"s": "75",
"lc": 1699867166.740093,
"c": "01HF3ZN20M0WRXTSQW7NZWYWWF"
"id": 1
