Mottivation
As UPnP integration of Home Assistant wasn’t working for MitraStar GPT-2541 GNAC router, I have created these scripts to get statistics from router directly using expect
Synopsis
I use expect (via pexpect in python) to connect to router and get lan & wan statistics for every interface of MitraStar GPT-2541GNAC (Bytes, Packets, Errors & Drops, Tx and Rx, LAN and WAN Interfaces).
It can be adapted to any other router that we can connect via ssh and get stats with similar commands to showlanstats or showwanstats used in this model.
Once I get statistics, I use another script to get individual values and write sensors in HA like this one:
- platform: command_line
name: WAN VoIP (veip0.2) KBytes tx
command: 'python3 /config/python-scripts/getstats/getdata.py /config/python-scripts/getstats/lanwanstats.txt veip0.2 tx B'
unit_of_measurement: "KBytes"
value_template: '{{value|multiply (0.001)}}'
Repo in: https://github.com/jpcozar/getstats-MitraStar-router-GPT-2541GNAC
