Thank you Obaldius
This is the idea here:
To turn on several security features on 3 security cameras under 2 conditions: the home alarm is on (on night or away mode) AND is night.
I also put 2 switches there to enable or disable this manually (StrobeOn/ StrobeOff) just to activate it at anytime regarding the conditions.
Then they are the cameras with the functions On and or… and the last colum is the “get status” function from where I want to get the status of this features and publish on the dashboard.
[{"id":"5caabfedce4684da","type":"tab","label":"Hik Alarm","disabled":false,"info":"","env":[]},{"id":"eaed690a9ebdee64","type":"server-state-changed","z":"5caabfedce4684da","name":"Alarm armed_night","server":"2328616d.4f48fe","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"alarm_control_panel.casa","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"armed_night","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"home/alarm","valueType":"str"}],"x":110,"y":40,"wires":[["2fd84c1b18168a47"],[]]},{"id":"2fd84c1b18168a47","type":"or-gate","z":"5caabfedce4684da","name":"Alarm ON","rules":[{"t":"true","propertyType":"msg","property":"payload","topic":"home/alarm"}],"outputTopic":"home/alarmOn","gateType":"or","emitOnlyIfTrue":false,"x":320,"y":100,"wires":[["539e707f27ee6608"]]},{"id":"e45912c4352ff12d","type":"server-state-changed","z":"5caabfedce4684da","name":"Alarm armed_away","server":"2328616d.4f48fe","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"alarm_control_panel.casa","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"armed_away","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"true","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"home/alarm","valueType":"str"}],"x":110,"y":100,"wires":[["2fd84c1b18168a47"],[]]},{"id":"539e707f27ee6608","type":"and-gate","z":"5caabfedce4684da","name":"Alarm + Night","rules":[{"t":"true","propertyType":"msg","property":"payload","topic":"home/alarmOn"},{"t":"eq","v":"true","vt":"str","propertyType":"msg","property":"payload","topic":"BigTimer"}],"outputTopic":"Strobe","gateType":"and","emitOnlyIfTrue":false,"x":540,"y":140,"wires":[["628659bd8ade3a3a"]]},{"id":"c111640b1c403c60","type":"server-state-changed","z":"5caabfedce4684da","name":"Alarm Disarmed","server":"2328616d.4f48fe","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"alarm_control_panel.casa","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"disarmed","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"false","valueType":"bool"},{"property":"topic","propertyType":"msg","value":"home/alarm","valueType":"str"}],"x":100,"y":240,"wires":[["2fd84c1b18168a47","628659bd8ade3a3a"],[]]},{"id":"b9ef5d42f35e1912","type":"hikvisionUltimateXML","z":"5caabfedce4684da","name":"Strobe On 54","server":"459e2fd7c861a60a","xmlText":"<?xml version=\"1.0\" encoding=\"UTF-8\"?>\r\n<EventTrigger version=\"2.0\" xmlns=\"http://www.std-cgi.com/ver20/XMLSchema\">\r\n <id>fielddetection-1</id>\r\n <eventType>fielddetection</eventType>\r\n <eventDescription>fielddetection Event trigger Information</eventDescription>\r\n <videoInputChannelID>1</videoInputChannelID>\r\n <dynVideoInputChannelID>1</dynVideoInputChannelID>\r\n <EventTriggerNotificationList>\r\n <EventTriggerNotification>\r\n <id>email</id>\r\n <notificationMethod>email</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>record-1</id>\r\n <notificationMethod>record</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n <videoInputID>1</videoInputID>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>beep</id>\r\n <notificationMethod>beep</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>center</id>\r\n <notificationMethod>center</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>whiteLight</id>\r\n <notificationMethod>whiteLight</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n <WhiteLightAction>\r\n <whiteLightDurationTime>0</whiteLightDurationTime>\r\n </WhiteLightAction>\r\n </EventTriggerNotification>\r\n </EventTriggerNotificationList>\r\n</EventTrigger>","path":"/ISAPI/Event/triggers/fielddetection-1","method":"PUT","x":990,"y":200,"wires":[[]]},{"id":"4e6ea4cfbd83ade7","type":"hikvisionUltimateXML","z":"5caabfedce4684da","name":"Strobe On 52","server":"fb40ac64326e12cd","xmlText":"<?xml version=\"1.0\" encoding=\"UTF-8\"?>\r\n<EventTrigger version=\"2.0\" xmlns=\"http://www.std-cgi.com/ver20/XMLSchema\">\r\n <id>fielddetection-1</id>\r\n <eventType>fielddetection</eventType>\r\n <eventDescription>fielddetection Event trigger Information</eventDescription>\r\n <videoInputChannelID>1</videoInputChannelID>\r\n <dynVideoInputChannelID>1</dynVideoInputChannelID>\r\n <EventTriggerNotificationList>\r\n <EventTriggerNotification>\r\n <id>email</id>\r\n <notificationMethod>email</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>record-1</id>\r\n <notificationMethod>record</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n <videoInputID>1</videoInputID>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>beep</id>\r\n <notificationMethod>beep</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>center</id>\r\n <notificationMethod>center</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>whiteLight</id>\r\n <notificationMethod>whiteLight</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n <WhiteLightAction>\r\n <whiteLightDurationTime>0</whiteLightDurationTime>\r\n </WhiteLightAction>\r\n </EventTriggerNotification>\r\n </EventTriggerNotificationList>\r\n</EventTrigger>","path":"/ISAPI/Event/triggers/fielddetection-1","method":"PUT","x":990,"y":80,"wires":[[]]},{"id":"062333c9a4fb0eca","type":"hikvisionUltimateXML","z":"5caabfedce4684da","name":"Strobe Off 54","server":"459e2fd7c861a60a","xmlText":"<EventTrigger version=\"2.0\" xmlns=\"http://www.std-cgi.com/ver20/XMLSchema\">\r\n <id>fielddetection-1</id>\r\n <eventType>fielddetection</eventType>\r\n <eventDescription>fielddetection Event trigger Information</eventDescription>\r\n <videoInputChannelID>1</videoInputChannelID>\r\n <dynVideoInputChannelID>1</dynVideoInputChannelID>\r\n <EventTriggerNotificationList>\r\n <EventTriggerNotification>\r\n <id>record-1</id>\r\n <notificationMethod>record</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n <videoInputID>1</videoInputID>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>center</id>\r\n <notificationMethod>center</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n </EventTriggerNotification>\r\n </EventTriggerNotificationList>\r\n</EventTrigger>","path":"/ISAPI/Event/triggers/fielddetection-1","method":"PUT","x":990,"y":380,"wires":[[]]},{"id":"80dec28db9de97a3","type":"hikvisionUltimateXML","z":"5caabfedce4684da","name":"Strobe Off 53","server":"abd3259d696964a1","xmlText":"<EventTrigger version=\"2.0\" xmlns=\"http://www.std-cgi.com/ver20/XMLSchema\">\r\n <id>fielddetection-1</id>\r\n <eventType>fielddetection</eventType>\r\n <eventDescription>fielddetection Event trigger Information</eventDescription>\r\n <videoInputChannelID>1</videoInputChannelID>\r\n <dynVideoInputChannelID>1</dynVideoInputChannelID>\r\n <EventTriggerNotificationList>\r\n <EventTriggerNotification>\r\n <id>record-1</id>\r\n <notificationMethod>record</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n <videoInputID>1</videoInputID>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>center</id>\r\n <notificationMethod>center</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n </EventTriggerNotification>\r\n </EventTriggerNotificationList>\r\n</EventTrigger>","path":"/ISAPI/Event/triggers/fielddetection-1","method":"PUT","x":990,"y":320,"wires":[["00ff4c2545ddf170"]]},{"id":"d4f082fc37fce540","type":"hikvisionUltimateXML","z":"5caabfedce4684da","name":"Strobe Off 52","server":"fb40ac64326e12cd","xmlText":"<EventTrigger version=\"2.0\" xmlns=\"http://www.std-cgi.com/ver20/XMLSchema\">\r\n <id>fielddetection-1</id>\r\n <eventType>fielddetection</eventType>\r\n <eventDescription>fielddetection Event trigger Information</eventDescription>\r\n <videoInputChannelID>1</videoInputChannelID>\r\n <dynVideoInputChannelID>1</dynVideoInputChannelID>\r\n <EventTriggerNotificationList>\r\n <EventTriggerNotification>\r\n <id>record-1</id>\r\n <notificationMethod>record</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n <videoInputID>1</videoInputID>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>center</id>\r\n <notificationMethod>center</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n </EventTriggerNotification>\r\n </EventTriggerNotificationList>\r\n</EventTrigger>","path":"/ISAPI/Event/triggers/fielddetection-1","method":"PUT","x":990,"y":260,"wires":[[]]},{"id":"628659bd8ade3a3a","type":"switch","z":"5caabfedce4684da","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":750,"y":220,"wires":[["4e6ea4cfbd83ade7","b9ef5d42f35e1912","02e3899a79cf7cb4"],["d4f082fc37fce540","80dec28db9de97a3","062333c9a4fb0eca"]]},{"id":"22f6e2317b49aa5b","type":"bigtimer","z":"5caabfedce4684da","outtopic":"BigTimer","outpayload1":"true","outpayload2":"false","name":"BigTimer","comment":"","lat":"-34.351158","lon":"-58.868846","starttime":"5004","endtime":"5003","starttime2":0,"endtime2":0,"startoff":0,"endoff":0,"startoff2":0,"endoff2":0,"offs":"0","outtext1":"","outtext2":"","timeout":"0","sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"day7":0,"month7":0,"day8":0,"month8":0,"day9":0,"month9":0,"day10":0,"month10":0,"day11":0,"month11":0,"day12":0,"month12":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xday7":0,"xmonth7":0,"xday8":0,"xmonth8":0,"xday9":0,"xmonth9":0,"xday10":0,"xmonth10":0,"xday11":0,"xmonth11":0,"xday12":0,"xmonth12":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"randon1":false,"randoff1":false,"randon2":false,"randoff2":false,"repeat":true,"atstart":true,"odd":false,"even":false,"x":320,"y":180,"wires":[["539e707f27ee6608"],[],[]]},{"id":"02e3899a79cf7cb4","type":"hikvisionUltimateXML","z":"5caabfedce4684da","name":"Strobe On 53","server":"abd3259d696964a1","xmlText":"<?xml version=\"1.0\" encoding=\"UTF-8\"?>\r\n<EventTrigger version=\"2.0\" xmlns=\"http://www.hikvision.com/ver20/XMLSchema\">\r\n <id>fielddetection-1</id>\r\n <eventType>fielddetection</eventType>\r\n <eventDescription>fielddetection Event trigger Information</eventDescription>\r\n <videoInputChannelID>1</videoInputChannelID>\r\n <dynVideoInputChannelID>1</dynVideoInputChannelID>\r\n <EventTriggerNotificationList>\r\n <EventTriggerNotification>\r\n <id>email</id>\r\n <notificationMethod>email</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>record-1</id>\r\n <notificationMethod>record</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n <videoInputID>1</videoInputID>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>beep</id>\r\n <notificationMethod>beep</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>center</id>\r\n <notificationMethod>center</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n </EventTriggerNotification>\r\n <EventTriggerNotification>\r\n <id>whiteLight</id>\r\n <notificationMethod>whiteLight</notificationMethod>\r\n <notificationRecurrence>beginning</notificationRecurrence>\r\n <WhiteLightAction>\r\n <whiteLightDurationTime>0</whiteLightDurationTime>\r\n </WhiteLightAction>\r\n </EventTriggerNotification>\r\n </EventTriggerNotificationList>\r\n</EventTrigger>","path":"/ISAPI/Event/triggers/fielddetection-1","method":"PUT","x":990,"y":140,"wires":[["00ff4c2545ddf170"]]},{"id":"1512c7b36da78405","type":"ha-switch","z":"5caabfedce4684da","name":"StrobeOff","version":0,"inputs":1,"outputs":2,"entityConfig":"123ae7c0.58ab28","enableInput":true,"outputOnStateChange":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"str"}],"x":540,"y":320,"wires":[["d4f082fc37fce540","80dec28db9de97a3","062333c9a4fb0eca"],[]]},{"id":"4ecdb0744a501dc6","type":"ha-switch","z":"5caabfedce4684da","name":"StrobeOn","version":0,"inputs":1,"outputs":2,"entityConfig":"4c6fd81453e019cf","enableInput":true,"outputOnStateChange":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"str"}],"x":540,"y":60,"wires":[["4e6ea4cfbd83ade7","02e3899a79cf7cb4","b9ef5d42f35e1912"],[]]},{"id":"00ff4c2545ddf170","type":"hikvisionUltimateXML","z":"5caabfedce4684da","name":"get state","server":"fb40ac64326e12cd","xmlText":"","path":"/ISAPI/Event/triggers/fielddetection-1","method":"GET","x":1380,"y":260,"wires":[[]]},{"id":"2328616d.4f48fe","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true},{"id":"459e2fd7c861a60a","type":"Hikvision-config","host":"192.168.40.54","port":"80","name":"Cam4","authentication":"digest","protocol":"http","heartbeattimerdisconnectionlimit":"3","deviceinfo":"{\"DeviceInfo\":{\"$\":{\"version\":\"2.0\",\"xmlns\":\"http://www.hikvision.com/ver20/XMLSchema\"},\"deviceName\":\"IP CAMERA\",\"deviceID\":\"a9004000-67db-11b3-81a4-08a189ea89c1\",\"deviceDescription\":\"IPCamera\",\"deviceLocation\":\"hangzhou\",\"systemContact\":\"Hikvision.China\",\"model\":\"DS-2CD2386G2-ISU/SL\",\"serialNumber\":\"DS-2CD2386G2-ISU/SL20210420AAWRF88038368\",\"macAddress\":\"08:a1:89:ea:89:c1\",\"firmwareVersion\":\"V5.5.801\",\"firmwareReleasedDate\":\"build 211105\",\"encoderVersion\":\"V7.3\",\"encoderReleasedDate\":\"build 210903\",\"bootVersion\":\"V1.3.4\",\"bootReleasedDate\":\"100316\",\"hardwareVersion\":\"0x0\",\"deviceType\":\"IPCamera\",\"telecontrolID\":\"88\",\"supportBeep\":\"true\",\"supportVideoLoss\":\"false\",\"firmwareVersionInfo\":\"B-R-G3-0\"}}"},{"id":"fb40ac64326e12cd","type":"Hikvision-config","host":"192.168.40.52","port":"80","name":"Cam2","authentication":"digest","protocol":"http","heartbeattimerdisconnectionlimit":"2","deviceinfo":"{\"DeviceInfo\":{\"$\":{\"version\":\"2.0\",\"xmlns\":\"http://www.std-cgi.com/ver20/XMLSchema\"},\"deviceName\":\"Camera 2\",\"deviceID\":\"a77ac000-6c92-11b3-81aa-4cf5dc411186\",\"deviceDescription\":\"IPCamera\",\"deviceLocation\":\"STD-CGI\",\"systemContact\":\"STD-CGI\",\"model\":\"DS-2CD2386G2-ISU/SL\",\"serialNumber\":\"DS-2CD2386G2-ISU/SL20210426AAWRF92351110\",\"macAddress\":\"4c:f5:dc:41:11:86\",\"firmwareVersion\":\"V5.5.801\",\"firmwareReleasedDate\":\"build 211105\",\"encoderVersion\":\"V7.3\",\"encoderReleasedDate\":\"build 210903\",\"bootVersion\":\"V1.3.4\",\"bootReleasedDate\":\"100316\",\"hardwareVersion\":\"0x0\",\"deviceType\":\"IPCamera\",\"telecontrolID\":\"88\",\"supportBeep\":\"true\",\"supportVideoLoss\":\"false\",\"firmwareVersionInfo\":\"B-R-G3-0\"}}","credentials":{}},{"id":"abd3259d696964a1","type":"Hikvision-config","host":"192.168.40.53","port":"80","name":"Camera 3","authentication":"digest","protocol":"http","heartbeattimerdisconnectionlimit":"3","deviceinfo":"{\"DeviceInfo\":{\"$\":{\"version\":\"2.0\",\"xmlns\":\"http://www.hikvision.com/ver20/XMLSchema\"},\"deviceName\":\"Camera 3\",\"deviceID\":\"c3d28000-a164-11b4-8333-44a64242ef3b\",\"deviceDescription\":\"IPCamera\",\"deviceLocation\":\"hangzhou\",\"systemContact\":\"Hikvision.China\",\"model\":\"DS-2CD2386G2-ISU/SL\",\"serialNumber\":\"DS-2CD2386G2-ISU/SL20210819AAWRG40807417\",\"macAddress\":\"44:a6:42:42:ef:3b\",\"firmwareVersion\":\"V5.7.10\",\"firmwareReleasedDate\":\"build 220830\",\"encoderVersion\":\"V7.3\",\"encoderReleasedDate\":\"build 220704\",\"bootVersion\":\"V1.3.4\",\"bootReleasedDate\":\"100316\",\"hardwareVersion\":\"0x0\",\"deviceType\":\"IPCamera\",\"telecontrolID\":\"88\",\"supportBeep\":\"false\",\"supportVideoLoss\":\"false\",\"firmwareVersionInfo\":\"B-R-G5-0\",\"manufacturer\":\"hikvision\",\"subSerialNumber\":\"G40807417\",\"OEMCode\":\"1\"}}"},{"id":"123ae7c0.58ab28","type":"ha-entity-config","server":"2328616d.4f48fe","deviceConfig":"","name":"switch config for StrobeOff","version":6,"entityType":"switch","haConfig":[{"property":"name","value":"StrobeOff"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":""},{"property":"state_class","value":""},{"property":"last_reset","value":""}],"resend":true},{"id":"4c6fd81453e019cf","type":"ha-entity-config","server":"2328616d.4f48fe","deviceConfig":"","name":"switch config for StrobeOn","version":"6","entityType":"switch","haConfig":[{"property":"name","value":"StrobeOn"},{"property":"icon","value":""},{"property":"entity_category","value":""},{"property":"device_class","value":""}],"resend":true}]
Regards
Chris
