Good morning. I need a little help on this project.
I’m trying to use the following block to let me adjust the “delayed_off” time for my PIR sensor. The goal is to let me adjust the value within home assistant to make it easier to dial in my settings, vs changing and pushing code in esphome constantly.
My problem is I don’t know how to get the number value from the template into the binary sensor. I don’t really understand lambda’s so I have been copy pasting and googling trying to figure it out. So far I can get the code to validate and push to the esphome, but adjusting the template value in homeassistant doesn’t change the delayed_off value for the PIR sensor.
Can someone point me in the right direction?
number:
name: "Pir Off Delay"
unit_of_measurement: s
min_value: -500
max_value: 500
step: 5
mode: box
update_interval: 5s
optimistic: true
restore_value: true
initial_value: 0
icon: "mdi:timer-sand"
entity_category: config
This gives me the adjustment within HomeAssistant. I can also see the number updating in the esphome logs.
binary_sensor:
- platform: gpio
pin: D7
name: "Master Bath Motion"
device_class: motion
filters:
- delayed_off: !lambda return int(id("pir_delay"));
I just can’t seem to get the number into the delayed_off: portion. I’ve tried variations of what I have there and at best i can get it to validate and push the code, but it never seems to do anything.
I’ve tried the following variations, among others, but as you can see I don’t really have a clue.
return id("pir_delay")
return id(pir_delay).state;
return int(id(pir_delay).state);
As a point of comparison. I’m trying to replicate this setup, which does work, but the setup is a little different. I can’t use the same on_value: … update portion because binary_sensor doesn’t have the .update function apparently.
number:
unit_of_measurement: "°C"
min_value: -20
max_value: 20
step: 0.1
mode: box
update_interval: never
optimistic: true
restore_value: true
initial_value: 0
icon: "mdi:thermometer"
on_value:
- lambda: 'id(dht_sensor).update();'
- platform: dht
pin: D6
temperature:
name: "Master Bath Temperature"
filters:
- calibrate_linear:
- 27 -> 23.77
- 29.11 -> 26.88
- lambda: "return x + id(temperature_offset_ui).state;"
humidity:
name: "Master Bath Humidity"
filters:
- calibrate_linear:
- 57 -> 53
- 52 -> 50
- lambda: "return x + id(humidity_offset_ui).state;"
update_interval: 300s
model: DHT22
thank you for the help.
