I am using the MAX cube component which works very well
However I would like to use the actual temperature as a sensor to use it in other automations. Is there a way to extract this from the thermostat component?
I haven’t checked the code for this component, but if it’s like other climate devices, then you can get the temperature from the current_temperature attribute:
sensors:
current_temperature:
friendly_name: Current Temperature
value_template: "{{ state_attr('climate.THERMOSTAT', 'current_temperature') }}"
unit_of_measurement: # put whatever is appropriate here
Thanks a lot this works like a charm
study_temperature: friendly_name: 'Study Temperature' value_template: "{{ state_attr('climate.study_wall_thermostat', 'current_temperature') }}" unit_of_measurement: '°'
Great! BTW, unit_of_measurement for temperatures is usually '°F'
or '°C'
Thanks found that one too
In case someone wants to use the target temperature (set temperature) from the wall thermostat, this is the code for it:
study_target_temperature:
friendly_name: 'Study Target Temperature'
value_template: "{{ state_attr('climate.study_wall_thermostat', 'temperature') }}"
unit_of_measurement: '°C'
This way I can use the cheap Max wall thermostat as temperature sensor and manual control for a room and run all automation (e.g. controlling the boiler and radiators) in Homeassistant.
I have 4 Hue motion sensors and find the opposite on all of them. All 4 are 1.5 to 2 degrees celsius LOWER than actual room temperature (checked with a medically calibrated thermometer).
It seems the Hue sensors are highly inaccurate on Temperature, and possbily quite inaccurate with LUX as well.
Short of individual calibrations, it looks like I will need an alternate solution for temperatures.
