Hi there,
here I have a little nice feature to get the current price for energy when i ask for it.
Integration used:
Epex Spot data integration (for forecast) and Tibber Integration for current price.
Would be working standalone with Epex.
I think this cant be used with copy and paste and needs a little bit of refinement for other home assistant instances.
The best thing is to get the alexa last media player and play the answer on that echo.
alias: "Alexa: Strompreis ausgeben"
description: ""
- platform: event
event_type: preisabfrage_strom
condition: []
- action: alexa_media.update_last_called
metadata: {}
data: {}
- action: notify.alexa_media_last_called
metadata: {}
message: >-
Der aktuelle Strompreis ist {{
('{:.2f}'.format((states('sensor.meineStraße_strompreis') |float
* 100 | float) |round(2)) | replace('.', ','))}} cent. Der beste
Strompreis ist heute um {{
states('sensor.startzeit_des_besten_strompreises') | as_timestamp |
timestamp_custom('%H:%M', default='unbekannt') }} Uhr und beträgt {% set
startzeit = state_attr('binary_sensor.bester_strompreis',
'data')[0]['start_time'] %}{% for data_block in
state_attr('sensor.epex_spot_data_net_price', 'data') %}{% if
as_timestamp(startzeit) >= as_timestamp(data_block.start_time) and
as_timestamp(startzeit) <= as_timestamp(data_block.end_time) %}{% set
price_per_kwh = data_block.price_ct_per_kwh %}{{ price_per_kwh |
round(2) | replace('.', ',') }}{% endif %}{% endfor %} cent
mode: single
To trigger this, you can create a sentence or more to activate a smart home element in home assistant.
Have fun with that.
