Will it work if I configure the robot to an other server?
Which server do you guys recommend/are working for you?
After i read out the token can I upgrade MiHome to the latest PlayStore version?
I believe it is not the one you are looking for. The right one is here. Just scroll to MiHome screen shots and use the link right before the version number (currently 5.4.5). Screen shots shown are from earlier MiHome versions so do not pay much attention to them.
You will need to remove the official version and install this one. If after that you go to āGeneral settings/Network infoā menu item for any device you will see the token there.
I didnāt succeed getting the miio tokens on Windows with the MiToolKit tool and the old Mi Home version on Android.
I end up using a modified Mi Home app that I guess itās similar to the ones already discussed here, as it also shows the token on āNetwork Settingsā.
After signing in into the app it also creates a ādevices.iniā file on the phone, inside a folder called āpluginā at root level. The file includes a list of devices with their type, name, IP, MAC and token. In case any device doesnāt show up, maybe you will need to open the device on the Mi Home app first, it happened to me with the Xiaomi infrared device.
In addition I would like to post this youtube video. It is in Spanish as well but even without knowing the language, someone can understand what to do. At least it worked for me⦠token through mihome app
Well, you can also just tap a few times on the Plug-in version (bottom screen when in āaboutā in the MiHome app) to get to the āWireless communication protocolā entry. There you can access the Password. Clicking on HUB info in the about screen should also give you more info regarding version etc
This worked! Had to set up my Xiaomi gear in the proper MiHome app on another phone, then sign in on the NPIRTUBE mod app. Found the token in the .ini file (after changing it to a .txt)
I am saving this for posterity! I canāt remember how many different ways I tried (miio in Ubuntu, MiToolkit, few phones, few android versions, few computers; but it never worked) and this works right away.
I had to do a full reset of my network and my vacuum generated a new token, I was so frustrated that I had to get the token manually with mySql on a very very old phone then I ran into this!
